Classic Hondas All Pre-1988 Hondas.
1989 civic dx cannot start
Old Apr 10, 2009 | 09:37 AM
Heeter's Avatar
New User
Default 1989 civic dx cannot start
Hi all,
My first post here.
Posting about my son's 1989 civic dx. It has a PGM-FI (1.5L, I believe).
It rotates over, but doesn't start. Doesn't even sound like it even wants to start. Just cranks over really easily.
The things we have done so far:
1- replaced fuel pump, fuel filter. (Ipulled one plug outand cranked over, does smell of gas when I do that.)
2- replaced coil, wires, cap, rotor, plugs (I tested plugs, there is spark getting to the plugs.)
3- checked the timing belt and adjusted the valve as per haynes manual.
4- Peeled the carpet back and removed the computer cover. The computer LED does flash once when it starts cranking over, and once when I stop cranking.
5- checked all fuses under dash and under hood, all good.
I am stumped as to what to check/fix next. It has been a week of trying to get this thing running.
Any help will be greatly appreciated.
Heeter
Old Apr 11, 2009 | 04:09 AM
E-AT_me's Avatar
Default Re: 1989 civic dx cannot start
wrong section.
Old Apr 11, 2009 | 09:45 AM
Infinityzer050's Avatar
Even though this is in the wrong section, have you tried replacing the main relay? that may be your problem
Old Apr 11, 2009 | 11:36 AM
Heeter's Avatar
New User
Sorry about posting in the wrong section guys,
I didn't check the main relay.
Would you know where it would be located?
Thanks again
Heeter
Old Apr 11, 2009 | 11:48 AM
Heeter's Avatar
New User
Hey guys,
I did a little research (google is such a beautiful thing) and found where it is located. I won't have a chance to change it until Monday.
post back then.
Hopefully that is my problem.
Heeter
Old Apr 12, 2009 | 05:09 PM
E-AT_me's Avatar
sorry, i could have atleast tried.
all of my main problems with the main relay have been intermittent.. do you know how to solder at all? it is located above the hood release and is a MAJOR pain in the butt to get out.. if you do know how to solder, it is a relatively easy fix. i've had 3 go bad in 3 different cars. they are all working fine now..
Old Apr 13, 2009 | 11:57 AM
Heeter's Avatar
New User
UPDATE:
My son went to the local pick-a-part, picked up 7 of them off different cars.
Total cost for all: $15
Got back to the garage and put one in, and the civic fired right up.
Thanks for all your help, guys.
Heeter
Old Apr 21, 2009 | 06:32 AM
Heeter's Avatar
New User
Hi Guys, this is another update.
Well, thinking that it was the Main relay (by it starting, gave us a false sense of hope), we tried others, then ended up buying a new one, but still it wouldn't start.
Finally gave yesterday, and got it towed to the Honda dealership, asked them to hook up to their tester. They told that it is a bad ECU.
Oh well...........................
Hopefully the local pick a part has them laying around.
wish us luck, lolol
Heeter
Old Apr 21, 2009 | 08:36 AM
E-AT_me's Avatar
i have one i can sell to you if you'd like. super-cheap!
Old Apr 21, 2009 | 12:56 PM
Heeter's Avatar
New User
I'll get back you in the morning, depending on our luck tonight at pick a part. PM me anyways, with your asking price, might as well get the ball rolling.
BTW, can any ECU work for that civic? My son's a 89civic dx with automatic with no options. Do I have to get one from the same model?
Thanks
Heeter
bobfortega
Mar 21, 2014 05:31 PM
CookstonKid
16
Aug 21, 2013 04:37 PM
W0Pdego
12
Oct 3, 2009 12:16 PM
plantmylotus
10
Oct 14, 2008 10:49 AM
SiRkid
Mar 13, 2008 04:04 AM
