D15B7 car drives and as soon as it gets warm dies out!
Old Apr 10, 2009 | 09:30 AM
Ghost78's Avatar
Default D15B7 car drives and as soon as it gets warm dies out!
So I got a 94 civic sedan for free with a blown up motor. I got a used motor on craigslist and swap it......
So the car drove fine for four months now it drives only for about 20 minutes and then back fires and loses power and dies out completely and won't star at all I do smell fuel fuses..... I change the fuel relay and same problem happens...... if I wait three hours the car will star and it runs fine till it warms up in 20 or 15 minutes and does it again, it stalls, back fires, and dies out completely....... is there a sensor that can cause this problem?
Any help will be appreciated......
Old Apr 15, 2009 | 06:57 PM
Ghost78's Avatar
Default Re: D15B7 car drives and as soon as it gets warm dies out!
The timing belt is good....... I took another IAC valve from the junk yard and swap it and it's does the same problem. I check all the wires and everything is like its suppose to be. Is weird that is run but when it get's warm it stall and the engine dies out, any help will be appreciated.
Old Apr 16, 2009 | 06:05 AM
fcm's Avatar
fcm
Old Fart
Check coil and ICM and connections to them.
Sounds like it is an ign. problem, [no spark] check for spark next time it will not run. 94
Old Apr 16, 2009 | 08:49 PM
civic_driver's Avatar
Could it be that the ignition timing is advanced too much? At higher RPMs while the car is cold, everything is good but once it warms up the RPMs drop and the engine backfires and dies.
Old Apr 20, 2009 | 04:26 PM
H24A96EK's Avatar
fcm^
Old Apr 21, 2009 | 08:20 PM
roni_xxp's Avatar
check your map sensor
Old Apr 22, 2009 | 02:50 AM
1992Si's Avatar
Replace the dizzy, your Ignitor is going bad, if you haven't figured it out by now.
Buy a rebuilt dizzy for about $160.00 it will be cheaper in the long run, trust me.
blackep925
Apr 12, 2008 04:59 PM
IhateMy93BlackHatch
Nov 23, 2005 12:03 PM
prototype80
Jul 28, 2005 08:55 PM
TURBO
13
Jul 10, 2004 04:23 PM
yorktonite
May 23, 2003 09:01 PM
