Brake booster VS. Intake Manifold?
Old Apr 10, 2009 | 08:39 AM
FearTheH's Avatar
Default Brake booster VS. Intake Manifold?
So i've had this minor problem with my em1, if i pump my brakes while the car is at idle then the idle rpms increase.... could this be from a vacuum leak between the brake booster and intake mani? I'm hoping thats all this is so i can just replace that funky shaped vacuum hose. Give me some input, thanks
Old Apr 10, 2009 | 08:44 AM
waaBAAH's Avatar
Default Re: Brake booster VS. Intake Manifold?
this is normal.
Old Apr 10, 2009 | 08:45 AM
85_305's Avatar
lol thats normal dude. EVERY car does that if you pump the brakes repeatedly.
Old Apr 10, 2009 | 08:52 AM
FearTheH's Avatar
well yeah, but rpms are going higher than they used to.. ehh maybe my cars just gettin old. I may replace the hose anyways just to see what happens. And i can think of a lot of cars that dont do that... so no, not "all" cars do that.
Old Apr 10, 2009 | 08:55 AM
85_305's Avatar
Fine it may not be all cars. But every single one of the 22 cars I'VE owned, do it.
Old Apr 10, 2009 | 06:57 PM
FearTheH's Avatar
I'm not tryin to argue with you haha, my z28 didn't do it. But I'm also not sayin that my civic didn't do it before, its just increased the rpms that it hits and I'm wondering if it could be a leaky vacuum line. It also does this very very random whining thing while the car if off, it kinda sounds like a fuel pump priming only a higher pitch...anyone else have this? Haha it pisses me off!
Old Apr 10, 2009 | 06:59 PM
Murk 'EM's Avatar
theres a check valve between the booster and the manifold check that to see if its working that high pitch sound might be a vacuum leak
callmechad's Avatar
fear my mom had the same issue and we replace the vacuum line and it lowered the rpm's alot. i would give it a shot. im not saying it would help. but ti did with my moms
Old Apr 10, 2009 | 07:46 PM
FearTheH's Avatar
Thanks, I'm not thinking that high pitched whining noise is going to be a vacuum problem, it only does it when the car is off, I could go a whole day or two without drivin it and it will still do it...it runs fine and has done it for several years, more annoying than anything.
Old Apr 11, 2009 | 05:07 AM
85_305's Avatar
Oh a high pitch whine? Hmmm. That could def. be a vacuum leak. Grab a can of ether and spray all the vac. lines and see if the rpms fluctuate.
Old Apr 12, 2009 | 11:57 PM
FearTheH's Avatar
ITS WHEN THE CAR IS OFF!!!!!! its not a vacuum leak!
Old Apr 13, 2009 | 05:03 AM
85_305's Avatar
Ya I just caught that.
I'm spent. Good luck.
blackhope121
Jan 15, 2008 09:19 PM
PatrickGSR94
Oct 10, 2007 01:52 AM
category5 SI
May 30, 2007 04:06 PM
Civd16y8
12
Aug 18, 2005 03:00 PM
slim9300
May 10, 2004 07:03 PM
