rear type r sway install on ek civic
i dont want to buy a expensive kit to install the rear itr sway bar what have u guys done to get it on your car pics would be great i am referring to mounting it on the subframe and endlinks any help is appreciated
Re: rear type r sway install on ek civic
your sure on my 94 teg and 94 civic i just used that cheap one that used a metal plate, spacer ,and washer, on them and never had a issue but what is a reasonbale one to get if i go that route
You are still taking a risk with a BSQ/Beaks kit on your Teg/Civic. However, the location of the sway bracket holes on the EK are located on the outer edge of the subframe past the bolts for the LCAs. That part is more vulnerable because the metal there is thin. The Teg/EG holes are located within the bolts for the LCA giving it more rigidity.
wait untill you get underneath the car with the swaybar... our **** is completely different from the jdm ctr.
your best bet is to get the asr kit. i've seen them go for lik 250.
ransack
44
10-11-2003 11:45 PM
PhoBichNga
02-16-2002 07:54 PM
