94 accord fog lights stopped working help?
Old Apr 10, 2009 | 07:23 AM
cd5cord_guy's Avatar
Icon6 94 accord fog lights stopped working help?
yesterday my fogs were working great, but when i left the movies they did not want to turn on.......i was pissed so today i checked the fuse and the wiring and everything seems to be in order so can it be the switch??
Old Apr 10, 2009 | 07:45 AM
Default Re: 94 accord fog lights stopped working help?
oops i forgot to mention i checked the bulbs too
Old Apr 10, 2009 | 08:05 AM
BBallz24's Avatar
Check the connections (where the harnesses connect). Maybe something got loose. CHeck back of plug, recheck the fuse (pull out and look over, maybe ever replace to make sure it's not fuse) check wires going into back of lights. Any place the wires might rub against metal? Possible the jacket got clipped and they shorted? Any break in wires?
Old Apr 10, 2009 | 08:14 AM
yeah i checked the connection, i changed the fuse the wires connected to the lights are in place, i basically redid the whole thing again, no breaks in wires. one thing i noticed is that the switch it struggles to be pushed in, could that have anything to do with it, it never did that before, i noticed right now that it only clicks from the left side
Old Apr 10, 2009 | 09:22 AM
TheMuffinMan's Avatar
He knows where you live!
Relay, fuse, etc
Old Apr 10, 2009 | 10:26 AM
yeah checked that as well, but the harness that i have does not have a relay? is it suppose to?.......
Old Apr 10, 2009 | 10:40 AM
redbull-1's Avatar
Most fog lights will use a relay in the circuit, as the relay is to use a low amperage circuit (for example the switch) to trigger a device on a high amperage circuit (the fog lights). A relay also is for safety reasons.
Since you don't have a relay, it is very possible the switch is burned out from the higher current.
dtapia's Avatar
yes if they are factory fog lights. because the fog lights will turn off when high beams are used i have a etm info for you
dinotapia@sbcglobal.net
email me i will send it to you.
Old Apr 10, 2009 | 10:54 AM
yeah because i have the oem fog lights and the oem switch just the wiring was done with a autozone kit......is it possible to add a relay to that type of wiring?
Old Apr 10, 2009 | 11:03 AM
daves91honda's Avatar
New User
try jumpering the switch if the lights come on it is the switch, dont leave it that way with out the fuse protection, also you can test the lights by temping them straight to the battery to see if they still work agian dont leave them that way. Alot of times the interal part of a switch can go bad, or get fried. I would also get a 12v tester to see what is getting and giving power. cost like 3 dollars at your local auto store saves lots of headache when you are wiring.
Old Apr 10, 2009 | 11:05 AM
dtapia's Avatar
well since you have a aftermarket wiring harness i dont think my info will help you as it only pertains to the factory wiring and relays and fuses.
good luck
Old Apr 10, 2009 | 11:09 AM
ill check out the lights and the switch to make sure.......thanks
Old Apr 10, 2009 | 11:17 AM
Ah aftermarket harness, dunno what to tell ya.
The OEM ones have a relay, as do the DEPO. Those can go bad and cause the lights not to work.
Old Apr 10, 2009 | 11:20 AM
do they even sell the harness by itself? thats one of the reasons i went aftermarket on the harness because i was not able to find one
Old Apr 10, 2009 | 11:21 AM
New User
yes you can put a relay in. they work like this, it is basically a switch that get turned on or off by a different circut, so if you had say 30amp lights you would run a 30 amp curcuit though the relay like a switch and to the lights. then you run a normal say 10 amp crcuit to a switch in the car Say toggle or the factory one, to the realy. When the the relay get a voltage(power) from it the switch, it turns the relay closed and the lights come on. but there is only 10 amps persay going though the switch( not firing it)
Old Apr 10, 2009 | 02:14 PM
so i found out its my switch......is there any way to repair the oem switch? or do i have to buy a new one?
Old Apr 10, 2009 | 02:23 PM
New User
that sucks I dont know if you can fix that one but if every thing else still works normal you can just use a cheaper toggle switch from your auto parts store, My guess would be that you cant fix that one, switchs are usually made to be thrown away when they break. good luck.
Old Apr 10, 2009 | 02:25 PM
yeah thats what i did ,i put one of those switches on.......its just for now i hope, but ill eventually buy another one....but thanks for your help
Old Apr 10, 2009 | 04:50 PM
redbull-1's Avatar
You might want to put a relay in the fog light circuit, to help prevent frying the switch.
Old Apr 10, 2009 | 05:11 PM
bsivoljr's Avatar
That should be an easy fix, all of the parts you need are available to you at any electronic store like Radio Shack, probably Best Buy, and also the Auto stores. GL
Old Apr 10, 2009 | 06:00 PM
oh i will put a relay, especially since i am going to get another oem switch....but thanks again
JDMHondaEJ8
Jul 20, 2009 06:43 PM
jiro
Honda Civic (2006 - 2015)
Jun 24, 2009 09:11 AM
queda
May 23, 2008 08:42 AM
Daniel98328
Feb 22, 2007 02:36 PM
rocaveli
Jun 9, 2005 03:33 PM
