Need help with overheating issue
Old Apr 9, 2009 | 08:09 PM
blumpfish's Avatar
Icon3 Need help with overheating issue
I have a 93 CX , 160k miles, I was riding home from work, it started overheating.. I pulled over and coolant was leaking. A hose busted so I replaced the hose, since then it has been overheating completely after 3-4 minutes of normal driving. I changed the thermostat and made sure the Fan is working and I'm not sure what else to check. Could someone point me in the right direction here
Old Apr 9, 2009 | 08:17 PM
Former User's Avatar
Default Re: Need help with overheating issue
The next step is a thorough bleeding of the cooling system. It may have some trapped air that is impeding coolant flow. Set the heater lever/**** on the dash to maximum heat and then follow the steps in the diagram:
Old Apr 9, 2009 | 08:40 PM
blumpfish's Avatar
Ah yeah, should've thought of that, when the hose busted.. it most definately let air int he system. I forgot to mention the heat is not working, it stopped working that day. Thanks for the quick and helpful reply.
Old Apr 9, 2009 | 08:43 PM
By the way, some people suggesting parking the car on an incline with the front end up during the bleed procedure to help all the bubbles come out.
Old Apr 9, 2009 | 08:49 PM
JarvisW's Avatar
Sol to Sol
Yep to both x2.
Old Apr 9, 2009 | 11:27 PM
nitrousb20_vtec's Avatar
you might have messed up the head gasket.
Old Apr 9, 2009 | 11:32 PM
JarvisW's Avatar
Sol to Sol
Yep, but he might as well try to bleed it first.
Then we can get into the nasty stuff
2002hondaCivic
Honda Civic (2001 - 2005)
Apr 13, 2018 03:50 AM
snibbor
10
Jun 7, 2011 09:40 AM
Circaskaterr
Feb 1, 2010 10:59 PM
msinsky14
Jul 10, 2009 01:34 PM
kakahoya
Feb 27, 2008 07:53 PM
