2001 turbo civic
My friend wants to get turbo for his 2001 civic. I remember reading something about not being able to do it becase it has aplastic intake manifold. is this true? i tried to find the post but i couldn't. and i didn't get to look at his car to see if it was plastic. and if it is, what would happen at about 6-7 psi? would it be able to hold? sory if this seems like a stupid question, but i did try searching on this site clubsi and all over different search engines. i know it could be done because i remember someone on here doing it. he must've had a custom intake manifold. Do they make aftermarket manifolds? ok, im gonna stop rambling now.
-Sean
-Sean
oh yeah, the non bypass type fuel system will be beautiful. You would have to run some kind of return line or add injectors.
[Modified by accordking, 10:56 PM 8/14/2002]
there is only 1 turbo on a 2k1 that I know of. And from what I hear from the guy it doesnt perform well.
The ULEV engines cant handle the boost well.
As for the plastic manifold, yes it is made of a super hard plastic. BUt that is not the reason a turbo cannot be made. The VW golfs (non vr6 and vr6) have the same style manifold, and they can boost fine.
I kinda like the plastic manifold. Keeps heat down. Try driving for a hour with a metal intake manifold, and you cant touch it, unlike the plastic onees.
[Modified by bhaz413, 2:35 PM 8/15/2002]
When I had my 2001 Civic apart I analyzed the manifold and that thing isn't going to hold any boost or N2o. It will shatter or explode.
you are correct about the n20. I have actually seen a 2k1 with a exploded manifold from a surge when this dude was using n20. As for turbo, it should be fine. But I wont be getting any forced induction with out the proper internals, and so far no one makes internal upgrades for the 7th gens.
do a search on http://www.2k1civic.com at least 2 people have turboed 2k1's
landmark2001
Jan 8, 2003 01:55 PM
