'99 Civic wire colors for installing CD player?
I have a red wire and red w/ black stripe on the car side left over?! Anyone know what these go to?
Not sure but hope this helps.
http://www.the12volt.com/installbay/...tail/1053.html
Did you read what Mikal92 posted? That should do it unless you're not getting power after connecting it as suggested. It's best to test the wires with a DMM (Digital Multimeter).
im having the same problem sumwhat in my 95 civic i figured out the power problem now im having the sound problem lol the yellow wire on the head unit is your main power sorse to the battery you can run a wire straight to the batt with a small fuse holder so itll blow out the fuse there insted of your stereo fuse and id have to look on my wireing and tell you the other 1 my wire harnes was cut as well so yea ill get back to you bro good let let me know if you fix it so i can fix mine to
Typical Honda/Acura "Typical" New Radio
Pin What It Is In Dash Wire Color Equivalent Wire Color
A Right Rear Spkr (+) Red w/ Yellow Stripe Purple
B Left Rear Spkr (+) Blue w/ Yellow Stripe Green
C Power Antenna Trigger Brown w/ White Stripe Blue or Blue w/ Wht Stripe
D +12 Volt Ignition Wire Yellow w/ Red Stripe Red
E Right Rear Spkr (-) Brown w/ White Stripe Purple w/ Black Stripe
F Left Rear Spkr (-) Gray w/ White Stripe Green w/ Black Stripe
G Ground Wire Black Black
H
H
Do Not Use
I
Do Not Use
J +12 Volt Battery Wire White w/ Yellow or Blu Stripe Yellow
K Dash Light Dimmer Wire Orange
L Left Front Spkr (+) Blue w/ Green Stripe White
M Right Front Spkr (+) Red w/ Green Stripe Gray
N
N
Do Not Use
O Left Front Spkr (-) Gray w/ Black Stripe White w/ Black Stripe
P Right Front Spkr (-) Brown w/ Black Stripe Gray w/ Black Stripe
ok i got mine working for your power wires your ignition on power wire on your car is yellow with red stripe connect the red wire on your hu and your maine battery wire is White w/ Yellow or Blu Stripe connect to the yellow wire on your hu hope this helps thats what i did with mine and it works fine good luck
Arent your wires labeled? Ive put numerous stereos in hondas and EVERY one ive done the harness is marked so all you have to do is match up the wires with the deck.
PS. /////Alpine decks FTW (colors even match up)
my honda doent have labled wires at all both his and mine were cut theres no adapter just wires i had to splice everything to do mine
Oregon
Audio / Security / Video
May 9, 2006 07:38 PM
97civic123
Mar 28, 2004 06:54 AM
Mike banX
Oct 28, 2003 06:59 PM
