dimmer wire for cd player?
Old Mar 3, 2006 | 03:16 PM
civiccoupe94's Avatar
Default dimmer wire for cd player?
i asked this question on another fourm on h-t, but i want a expert answer before i do this. i have a 94 civic dx coupe, and my cd player has a dimmer wire, but my car doesnt (i bought it like this, the wires in the back of the deck is all screwed up). so does the illumination wire behind the eg clock work if i tap it to the dimmer wire of the cd player? i dont want to mess up the cd player by tapping into a wrong wire or something. what other wire could i use?
its like blinding me when i drive on highway stretches that has no highway lights
Old Mar 3, 2006 | 04:23 PM
fcm's Avatar
fcm
Old Fart
Default Re: dimmer wire for cd player? (civiccoupe94)
Your 94 should have an illumination wire in the oem radio harness, it is a red/black wire, (K) in this diagram... http://www.installdr.com/Harnesses/HA-Wiring.pdf
94
Old Mar 3, 2006 | 06:03 PM
phateless's Avatar
do a google search for pinouts. you probably have an alpine headunit, right? i went through this same thing on my 94 accord when i first hooked up my cda 9807. if you bought a wire harness adapter (which you should have) there's a wire on there that's already set up for that. i pulled my alpine out of my accord and popped it into my teg (gotta love the plug and play of that harness adapter) and lo and behold, the dimmer function still works! do it right. don't do any tapping.
Old Mar 3, 2006 | 07:53 PM
suspendedHatch's Avatar
Default Re: (phateless)
Dimmer wire?! Just dont hook it up. I can't remember the last time I hooked up an orange wire...
Old Mar 3, 2006 | 09:04 PM
well i didnt have the harness adapter cause all my wires are screwed up behind the deck (theft) and my speaker wires are individually added, and i ran a wire to the battery + fuse , and the ground.
its alright when i drive in the city, but on the highway stretches with no highway lights.. it really distracts me!!
Old Mar 3, 2006 | 09:23 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
either find the wire behind your factory radio or which fcm gave you the diagram. or grab it at the clock. it is the same color. All it does is show 12 volts when the parking lights come on. Hell you can even grab it at the fuse block. Should work no problem. I never really ever hook up the dimmer anyway. Most customers don't want it, lol
Old Mar 3, 2006 | 09:39 PM
phateless's Avatar
at first i didn't hook it up, but it bugged the **** out of me after a while, so i hooked it up later.
Old Mar 3, 2006 | 10:42 PM
k thanks a bunch guys.. voltmeter + 10 minutes of my time tomorrow
Old Mar 10, 2006 | 11:58 AM
vmoua509's Avatar
Default Re: (civiccoupe94)
here are you factory wires..... check out http://www.the12volt.com
1994 Honda Civic Stereo Information
Constant 12V+ Blue/White
Switched 12V+ Yellow/Red
Ground Black
Illumination Red/Black
Dimmer n/a
Antenna Driver's Pillar
Front Speakers 6 1/2" Doors
Left Front (+) Blue/Green
Left Front (-) Gray/Black
Right Front (+) Red/Green
Right Front (-) Brown/Black
Rear Speakers 5 1/4" Rear Deck
Left Rear (+) Blue/Yellow
Left Rear (-) Gray/White
Right Rear (+) Red/Yellow
Right Rear (-) Brown/White
Riptide101
Audio / Security / Video
Sep 17, 2007 01:39 PM
civiccoupe94
Mar 2, 2006 09:08 PM
ineedmoney
Jun 3, 2004 10:30 PM
AaronJ
Jan 12, 2004 07:48 PM
RAWbertCuBus
Sep 19, 2003 07:02 PM
