No power when turned to the on postion
Old Apr 9, 2009 | 08:33 AM
91integraLSVTEC's Avatar
Default No power when turned to the on postion
Hey guys I went to turn on my car this morning and noticed that the dash lights would turn on in the on postion but seemed there wasnt enough juice to start the car. So i jumped it and now the dash lights doesnt turn on at all when i turn it in the on postion. The headlights work and everythign else except for the starting system. I checked my ground, and battery voltage with a mulitimeter and both are good. Can anybody give me some trouble shooting advice? Thanks.
btw am I the only one that thinks the new h-t search engine sucks?
Old Apr 9, 2009 | 10:32 AM
infinitypro12's Avatar
Default Re: No power when turned to the on postion
So, you can't start the car, dashlights don't work, but your parking/headlights work? Very interesting...bump.
Old Apr 9, 2009 | 10:33 AM
fireblaze2k1's Avatar
Did you check your fuses?
Old Apr 9, 2009 | 10:40 AM
Former User's Avatar
Definitely check for blown fuses. Also clean the battery posts, connectors, and ground wire attached to the engine bay.
If you put the transmission in neutral or park and you wire battery power directly to the starter solenoid (Blk/Wht wire), does the engine crank?
You might also want to check whether the ignition switch is bad.
kyler253
13
Oct 24, 2012 03:50 PM
lostinmiself
26
Jul 11, 2010 06:39 PM
JdmEg6andS13
Nov 21, 2005 12:55 PM
RockLee`
11
Sep 3, 2005 03:49 PM
cademan
Jul 19, 2004 03:42 PM
