Z6 cam vs. Y8 cam...Good Info!!
I know that much research has been done comparing the two heads and the Z6 seems to be the winner in terms of flow, but looking at these numbers which are sourced from http://www.knology.net/~jediklc/specs.htm Im not a cam expert but it looks to me as though te Y8 has better numbers, SO would the z6 head y8 cam be the better setup?
D16Y8
246/230 Advertised Duration
208/191 Duration @ 0.050"
393/369 Gross lift
110 Lobe Seperation
D16Z6
244/228 Advertised Duration
208/192 Duration @ 0.050"
384/370 Gross Lift
D16Y8
393/369 Gross lift
110 Lobe Seperation
D16Z6
384/370 Gross Lift
the difference there seems marginal. not enough to notice if you swapped.
what would be better... an akmee cam, or any other aftermarket street cam. reginds are good too, if you want a more affordable option.
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/akmee-d16z6-type-s-cam-result-6-whp-peak-19-5-whp-%40-7700-a-1401767/
check it out.
check it out.
Where could i find a Good Aftermarket cam for my Z6. everyone only sells for DOHC's. and could i put a stage 1 cam in with stock valve springs in all?
well im curently building a motor and i have almost every d series motor to work with d15b, z6, y7, y8 so since its all free would it be a usefull upgrade
"The reason why a regrind will not measure truly is that since the base circle of the cam is now smaller, the contact patch of the cam follower is now contacting the lobe in a different place for where it was designed to contact, which throws off the rocker ratio and makes the valve move slightly out of sync with the lobe of the cam. It is not uncommon for many poor quality aftermarket Honda cams to be ground off by a few degrees."
-Honda/Acura Engine Performance
-Mike Kojima
-Mike Kojima
-Mike Kojima
-Mike Kojima
ya and its junk. for the money(hell they dont even make it anymore) you can get wayyy better.
care to tell that to bisi or wil at exospeed?
-Mike Kojima
-Mike Kojima
-Mike Kojima
-Mike Kojima
