Quick trans question
Convert it! Single can trannys are dirt cheap. You van get the pedal assembly and hydros from a wrecking yard and the whole for the clutch master is allready in the firewall. You just have to buy the trans mount.
as long as it's the same engine block it should go on fine though. I believe that those cars have the same mounts.
possible, but not practical. you'll have fewer problems converting to manual.
They are both auto? It will bolt up just fine. You'll have some wiring to do though. Not gonna give you more problems than converting it to manual. If the OP is asking this then a manual conversion probably isn't gonna be a walk in the park for him.
dude, no offense, i could do the manual conversion, done it before...my friend has no want to have a manual, just wanted to know for sure if it would bolt up because i wasnt sure
budget
Feb 18, 2007 09:52 AM
thugciti01
Oct 12, 2005 01:12 PM
