For sale: JRSC GSR ported head, suspension, Wagovan speaker pods...
Old Apr 8, 2009 | 09:53 PM
Jaker's Avatar
Default For sale: JRSC GSR ported head, suspension, Wagovan speaker pods...
Here's some goodies for sale. I will ship everything except for the exhaust, as that would be a pain in the ****. I will charge actual shipping charges. Paypal is the prefered form of payment. 1st come 1st served. No dibs please.
[SOLD] Ellusive rear speaker kit for the Wagovan. These are grey. The kit is mostly complete. All that is missing are a couple screws, the actual instructions and the wire ends for plugging into the speakers. The brackets are there, the bolts to hold them are there, the wiring, and the 4 sections of plastic. $75. [SOLD]
Wagovan 2 1/2" exhaust system. There a couple spots where it goes down to 2 3/8", but for the most part it's all 2 1/2". Includes the muffler, 2 1/2" high flow cat that passed emissions testing 6 months ago (car's been parked for 2 months), 2 1/2" exhaust donut, stainless steel exhaust pipe outlet from muffler. All you need is a gasket and bolts/nuts for the midpipe to muffler flange and a 2 1/2" outlet from your header. Otherwise, this exhaust would be pretty easy to adapt to an OEM header outlet. $100.
[SOLD] Suspension Techniques Drop Forks. these drop the front end .75" with OEM springs. They also extend the shock like the extended top hats that everyone has been making if you don't lower your car too much. They fit the larger diameter front shocks from the 92-up Civics and Integras. $60. [SOLD]
[SOLD] Wicked Tuning rear toe control arms. Brand new in the package. $60. [SOLD]
[SOLD] 68mm LHT Performance throttle body. Brand new unused, and in perfect condition. Comes with a brand new Omni Racer TPS with gasket and screws. The TB has been modified to eliminate the port on the top for the MAP sensor, and the FIT valve ports on the botom of the TB have been closed off with an aluminum plate and silicone. The MAP hole could easily be opened back up with a few minutes of careful Dremel application. $125. [SOLD]
Johnson water circulation pump. 12v. pump for circulating water through one of those LHT supercharger intercooler cores. Brand new unused. $50.
[SOLD] H&R helper springs. Code 105-60-40. Roughly translates to 105mm long, 60mm inside diameter, 228 in/lbs. Brand new unused. $25 for the pair. [SOLD]
[SOLD] JRSC supercharger kit. Manifold is for B16 heads (will also fit ITR head). This is not a complete kit. I repeat, this kit is incomplete. The manifold has no cracks in it. The supercharger (M62) is in good condition. The bearings spin freely. The coating on the rotors is in good condition. One lobe (see photo) has the coating flaked off. The blower pulley is 4.0" and the outside edge of it has some nicks in it. The rest is intact. What you see is what you get. I don't have any of the other stuff. $600. [SOLD]
[SOLD] Complete Suspension Techniques EF 22mm rear swaybar kit. Bright green powdercoat. In really good condition. $75. I can take pics if you need them. [SOLD]
I also have a GSR B18C1 cylinder head which has been ported by Ed's Racing Heads for forced induction. It has a full Ferrea valvetrain (springs, valves .5mm o.s. on intake, 1mm o.s. on exhaust, retainers, new guides). The head was fully rebuilt, and has about 3,000 miles on it. Comes with ITR valve cover and Password JDM carbon fiber spark plug wire cover. The #5 cam journal on the exhaust side has some minor galling on it from the cam catching on the casting. Also, there is 1 bolt broken off in the head. This bolt is the small 6mm (10mm socket for the head) that bolts down beside the cam seal. This is not a critical area for the cam oil clearance. No Vtec solenoid, no cams, no camgears, no manifolds. $600.
I will have some pictures of this for anyone that is interested in seeing them (interested buyers).
[NEW ITEMS]
[All headlights are sold] I also have 2 sets of EF Hatch/CRX/Wagon headlights. 1 set is 90-91 in excellent condition with all 4 bulbs. $50. The other set is 88-89 in great condition with 4 bulbs as well, but one of the little ball sockets for the adjustment is gone. I needed it for another set of headlights. $25. Here's a couple pics of the 90-91 lights. I'll have pics of the 88-89s up later. [All headlights are sold]
MSD Soft Touch rev limiter. This is a stand alone rev limiter that cuts spark instead of fuel like the OEM Honda does. I used it because I felt that the fuel cut was a little too rough on my motor when I'm tuning it on the ragged edge. Now Hondata has spark cut built in. It wires in just like an MSD spark boost box (6A, 6AL) would, and uses the chips for setting the rev limit. It comes with a 6,000 and a 7,000 chip. $50.
[SOLD] A set of 4 Acura OEM 15x6 Integra meshies wheels with Falken tires in rough shape (205/50-15). I think the model is the 512, but can't remember for sure. The rims are painted black with silver lip, but they're in rough shape. They're still round, but the lips are kinda chewed up, and the paint has chipped off in a few places. The tires have a lot of wear, but they're not "bald" anywhere, and there's no cord showing at all. I want to sell as a package, and not deal with the hassle of dismounting the tires. $125 plus shipping. [SOLD]
Old Apr 9, 2009 | 08:26 AM
Jaker's Avatar
Default Re: For sale: JRSC GSR ported head, suspension, Wagovan speaker pods...
Bump for some stuff sold already.
Old Apr 9, 2009 | 12:37 PM
Jaker's Avatar
Added a couple parts to the list.
Old Apr 10, 2009 | 11:20 AM
Jaker's Avatar
Bump me up!
Old Apr 10, 2009 | 08:16 PM
Jaker's Avatar
Keeping this off the last page!
Old Apr 11, 2009 | 10:34 AM
Jaker's Avatar
Bump
Old Apr 11, 2009 | 01:00 PM
Jaker's Avatar
Speaker pods and Teg wheels are sold.
Old Apr 12, 2009 | 01:34 PM
Jaker's Avatar
Bump!
Old Apr 13, 2009 | 05:00 PM
Jaker's Avatar
Bump2!
Old Apr 15, 2009 | 04:29 PM
Jaker's Avatar
Bump for more stuff sold.
Old Apr 23, 2009 | 07:16 AM
Jaker's Avatar
Still a few items left. Im now entertaining offers on what remains.
Renegade
Jun 7, 2005 08:44 PM
5thgencivic
18
Jan 21, 2004 05:48 PM
JforJonathan
Jul 8, 2003 08:05 PM
420aNT
Nov 29, 2002 06:21 AM
