TPS Sensor adjustment & Vtec on obd2/ob1 ecu
I've recently swapped a b16a2 on my 97 ek hatch. im getting tps sensor code 7. i've just put in a new tps sensor. when i move it around, but i can never get where the car would run right. anyone know how to adjust the tps sensor? i tried moving it, tighten bolts....testing the car...but rpm always drops low and comes back up....most of the times, when the car reached the normal operating temp, it shuts off when rpm drops after letting off the throttle.
as for the vtec...i got a 96-98 engine harness, the one with no vtec.....the guy who gave it to me was running a obd2a ecu and wired up the vtec himself on his swap same engine as mine and everything was working correctly. Im currently running a obd1 p72 ecu with a jumper harness. do i have to rewire the vtec on the engine harness? or just plug and play with the obd1 Ecu w/ jumper harness?
bump, anyone?? hate driving my car when it feels like it gonna shut off every time i let off the gas. and alot of the times it does shut off. i tried moving tps different positions...but car still does it..in some positions its worse and others it helps but still there.
no, didnt change throttle body, only replaced the TPS sensor. Car is running like crap....only codes it get is 7 and 21, 22......
ok, ill try that when i have time....as of now...the code for the tps is gone....but the idle is still screwed up...same thing..surges all the time...even when in throttle but its hard to feel it. I keep pedal in place, and u can feel the car surging a bit. when i left of throttle rpm drops and sometimes car shuts off. codes i have now is 21, 23
i've always had code 23 as knock sensor isnt wired up on my p72, car always ran fine when i had it on my obd1.
hook up a scanner with live data. and move it till it hits 10% then pin your two wire connecter in the pass side of the car by the ecu. unplug the iac valve. then start the car. set base idle at 720 rpms. turn off car then un plug pin and plug back iac. set timing to 16deg btc or 12deg btc what ever your car calls for. car off pull ecu fuse 2 mins install fuse start car. let idle 10mins then turn on lights 2 mins, turn off light 2 mins turn on a/c on 2 mins turn off a/c let idle 2 mins. then turn off car.
if idle is still messed up. take intake off and plug the fast idle thermo valve hole when car is hot . of it fixes it then its the FITV done -EAF-
ill try unpluging the fitv while car is at normal operating temp once i get my car back, damn cops towed it because someone around where i parked it complained about my alarm, that it kept ringing all the time. is that possible? can they towed it for that reason?
mhewitt
May 1, 2011 10:45 AM
crispek9
19
Apr 25, 2007 07:41 AM
daeaudio
15
Sep 17, 2005 11:21 AM
CrazyKoreanCrx
Apr 20, 2004 10:25 AM
