can the block be fix
Old Apr 8, 2009 | 04:03 PM
Japankid's Avatar
Default can the block be fix
i have a short block b-series vtec and was thinkin of geting it fix
the knock sensor is chip can it be weld shut?
Old Apr 8, 2009 | 04:07 PM
Japankid's Avatar
Default Re: can the block be fix
Old Apr 8, 2009 | 05:04 PM
toyomatt84's Avatar
Sanji
Yes. Weld and re-tap the hole.
Old Apr 8, 2009 | 05:07 PM
Japankid's Avatar
can i plug it up ? it's a vtec block
thanks for the info
Old Apr 8, 2009 | 05:36 PM
mar778c's Avatar
Community Builder
Community Influencer
You can drill and tap elsewhere for a new location for a knock sensor.
Old Apr 8, 2009 | 06:11 PM
downest's Avatar
That's not where the knock sensor goes.
Old Apr 8, 2009 | 07:36 PM
Nick Z32's Avatar
like toyomatt said.. weld and retap
just CLEAN it very very good
Old Apr 8, 2009 | 08:14 PM
ManBearPig4silly's Avatar
Super easy fix. Any shop could do that.
Old Apr 8, 2009 | 08:49 PM
slammedobd1teg's Avatar
thats not the knock sensor, thats oil pressure, you can plug that, or get it welded and retaped.
Old Apr 9, 2009 | 12:35 PM
EARLdaSQUIRREL's Avatar
official honda whore
ya, thats not the knock sensor, that is the where the oil pressure unit goes
if it was the knock sensor hole you could have just left it, but since its the oil hole it will have oil coming out of it so it needs to either to plug welded (and get an adapter that goes on the oil filter) or be welded and retapped
Jaz760
Apr 7, 2012 06:37 PM
skimb37
Jan 1, 2009 08:31 PM
joedr
Nov 9, 2008 12:11 PM
dizzyroc88
16
Jul 16, 2006 03:44 PM
integramic
Sep 15, 2004 05:52 AM
