reusing Headgasket?
Old Apr 8, 2009 | 01:15 PM
TravisCadello's Avatar
Default reusing Headgasket?
I put this brand new head gasket on and i think i have a bent valve or to. and i need to take my head back off. this will be my 3rd head gasket wasted if not.
the engine Never started or headed up or even tried.
Old Apr 8, 2009 | 01:33 PM
JarvisW's Avatar
Sol to Sol
Default Re: reusing Headgasket?
When you torque it down, i think that ruins it.
BTW, "Houston Texas, TX," ?? lol
Old Apr 8, 2009 | 01:42 PM
lol ya
Old Apr 8, 2009 | 01:57 PM
JDMJester's Avatar
Agreed. Just to be safe, might as well replace it. It may or may not save you a headache later on.
Old Apr 8, 2009 | 03:00 PM
00Red_SiR's Avatar
All Motor Mentor
If the head gasket wasn't heat cycled, you can reuse it. That's what "ruins" them.
Old Apr 8, 2009 | 03:01 PM
what does head cycled mean?
Old Apr 8, 2009 | 06:44 PM
00Red_SiR's Avatar
All Motor Mentor
It means this.
Old Apr 8, 2009 | 06:45 PM
so it may still be good? mine had some specil blue **** on it for a better seal
Old Apr 8, 2009 | 06:47 PM
Murk 'EM's Avatar
no the head gasket will not be good.. its 3 diffrent "sheets" of metal and its a crush gasket so once you "crush" it down and take it off its no good it wont seal like its suposed to and youll have to take it off again and get a new one.
do it right the first time save your self the extra work
Old Apr 8, 2009 | 11:52 PM
ddd4114's Avatar
What special blue ****? You didn't use something like RTV did you?
Old Apr 9, 2009 | 09:27 AM
Hell No lol, i dont know but when i got it it said on the package their is a specil blue sealant around the head gasket to help with the envirmonetal safety and for a better and longer lasting seal. so i took it out and it was all metal 3 sheets and had blue on it. it was dried up the blue stuff though. it a new kind of gasket they just started making.
Old Apr 9, 2009 | 11:08 AM
fireblaze2k1's Avatar
What motor is it for?
Old Apr 9, 2009 | 11:33 AM
tony7626's Avatar
just get an oem one...dont get anything from autozone. you can get oem for around 60-70
Old Apr 9, 2009 | 11:57 AM
00Red_SiR's Avatar
All Motor Mentor
That is not true, it might be true for something like an exhaust gasket. Only the middle section is metal, the top and bottom are what forms the seal, the metal middle gives the gasket integrity. Many people including myself have torqued a head town with a new gasket in order to clay the motor etc, this does not affect using it. It's the HEAT, once you run the engine that alters the gaskets characteristics and requires it to be replaced once the head has been removed again.
Old Apr 9, 2009 | 04:21 PM
Sr420Det's Avatar
I've run used 3 layer head gaskets, used one layer gaskets and never really had a sealing problem. But my boy has a oring and step decked block, that we cant seem to get to seal. So.........
Old Apr 10, 2009 | 10:59 PM
d16z6. i think imma reuse it i took it off and it still looks brand new.
Old Apr 10, 2009 | 11:05 PM
JarvisW's Avatar
Sol to Sol
Yeah, they may be right, about the heat... it only will cost you time if they are wrong, so might as well
Old Apr 10, 2009 | 11:29 PM
waaBAAH's Avatar
agree ^^^^
lilshady6796
Feb 3, 2009 07:59 PM
da_33
Jan 11, 2007 11:12 AM
EG civic
Jul 20, 2006 07:58 PM
Chuethou_b18c5
May 1, 2006 11:51 PM
