CTR pulley...OEM better?
Old Apr 8, 2009 | 09:53 AM
a1320honda's Avatar
Default CTR pulley...OEM better?
So after praising my CTR pullet for over 2.5 years, i finaly had an oil pump shatter on me. I dont know if it was the pully for sure, but i am revving the motor to 9000. My question is would i be better off using an OEM crank pulley? Im just so unsure at this point and searches have revealed nothing but arguments back and forth.
my pump for posterity.
Old Apr 8, 2009 | 11:06 AM
BlakeJ53's Avatar
Default Re: CTR pulley...OEM better?
ATI or Fluiddampner FTW
Old Apr 8, 2009 | 01:22 PM
Ls_dx's Avatar
Damn. Thats some carnage.. the CTR has no dampening in it so it would just transfer any harmonics to the pump.. I would say go with an OEM or ati/fld.
Old Apr 8, 2009 | 02:42 PM
Blown90hatcH's Avatar
w00t
Old Apr 8, 2009 | 02:54 PM
Top Speed's Avatar
you have to have a dampener of some sort
Old Apr 8, 2009 | 05:55 PM
purpleh22's Avatar
I have an H22. They are known for shattering oil pump gears. When I turboed mine, I used the OEM balancer and Pro Drive gearing. If you decide to use a non OEM unit, see if you can find records of tests on aftermarket harmonic balancers. Some of the results were interesting.
Old Apr 8, 2009 | 06:00 PM
LSTEG96's Avatar
CTR is OEM????
Old Apr 8, 2009 | 09:29 PM
turbociv910's Avatar
Yep, not the first time Ive seen this happen from the CTR pulleys.
Old Apr 10, 2009 | 03:01 AM
Rob§'s Avatar
Did you do anything maintenance wise to the pulley or anything with in those two and a half years, i just bought the same pulley and i am hoping that it will hold up if properly maintained. i have yet to see rubber on a stock pulley to indicate a Harmonic Balancer... i had to use 2 blocks to complete my build both came with stock pulley's on and neither had any rubber i went to Honda to order a brand new one and it was the exact same. Is the rubber inside or something????
that had to hurt tho, i completely agree that that blows hardcore.
Old Apr 10, 2009 | 03:12 AM
Rob§'s Avatar
Sorry for all the questions but i have to ask. How did it hold up for those 2.5 years it was on? was this car a DD? how many miles did you drive on that pulley? was there any warning that it was going it did it just explode? where did you get it from? how many belts did you have hooked up to it, 3? 2? 1?
Thanks
Rob §
Old Apr 10, 2009 | 03:54 AM
Tony the Tiger's Avatar
Thanks
Rob §
It's not really about how much mileage the car has... It has more to do with the amount of power the engine is making as well.
A CTR crank pulley and factory oil pump gear can last probably 10 years if it was running at 200 WHP and 4 PSI of boost for example. It may only last one pull if it was making 400 WHP instead.
Old Apr 10, 2009 | 03:58 AM
Rob§'s Avatar
Thanks for the explanation Tony, i am just trying to get numbers for statistics you know what i mean covering all ends. i am looking at boosting 15lbs and have 325Whp according to the tuning shop that ordered most of my parts. i just dont want to lose an engine dude to a pulley
Thanks
Rob §
Old Apr 10, 2009 | 04:17 AM
kyden's Avatar
all the pulleys i have has the rubber on them. it is maybe an inch or so from the outside.
Old Apr 10, 2009 | 04:25 AM
Rob§'s Avatar
Can you post a pic because i dont understand how i can get a brand new one straight from Honda and not see any rubber if its suppose to be there please post a pic
Thanks
Old Apr 11, 2009 | 07:49 AM
Topdawgg's Avatar
OEM is fine
ATI or Fluidampr if you want to be safe..
Ive shattered an oil pump on the dyno, wasnt fun at all..
didnt hurt anything (thank god)
I run the ATI damper now
NABeastRR
48
Jun 21, 2007 01:17 PM
Hondizzle!
Apr 28, 2007 06:19 AM
melovesboost
Feb 25, 2007 02:30 PM
drintegra
Aug 7, 2006 05:20 PM
