LoveFab SST +GT3582R
Old Apr 8, 2009 | 09:20 AM
frenzyh22's Avatar
Default LoveFab SST +GT3582R
I am getting really close to ordering all my turbo build-up parts and was just wondering if it is absolutely necessary to run dual waste gates with this setup?
Old Apr 8, 2009 | 09:35 AM
kyden's Avatar
Default Re: LoveFab SST +GT3582R
is it divided?
Old Apr 8, 2009 | 09:44 AM
ScorpionT's Avatar
If its a twin scroll manifold, you should really run two wastegates. If its a just a standard manifold, you dont really need to run two unless its a bigger turbo.
Old Apr 8, 2009 | 09:53 AM
EARLdaSQUIRREL's Avatar
official honda whore
it depends on how much boost you want to run, if you want less than 10 or so psi i would go with twin 38's(new vband ones) or 44's if you have to
Old Apr 8, 2009 | 11:37 AM
frenzyh22's Avatar
yaa i forgot to mention it is a twin scroll so it will have a divided t4 flange on it. I plan to run 15-20 psi street and 30-40psi on c16. does everyone who has twin scrolls use dual gates or is it just used for quicker spool up?
Old Apr 8, 2009 | 12:01 PM
for "twin scroll" or divided inlets you pretty much have to use 2 gates unless they merge the 2 into one
so plan on buying 2 gates for it
is there a t4 gt35r that has a divided housing?
Old Apr 8, 2009 | 12:18 PM
ScorpionT's Avatar
Earl, there are a couple divided T4 housings for the 35R. ATP and Garrett both make them.
Frenzy, you have the manifold yet? If you dont, just order the WGs from Lovefab.
Old Apr 8, 2009 | 12:24 PM
ya i have the t4 atp housing, but didnt know and cant find an atp divided t4 housing for the 35r
Old Apr 8, 2009 | 01:18 PM
frenzyh22's Avatar
I havent bought the manifold yet, but looking at the pictures on lovefab's website it looks like they mount the wategate in the center on the front of the collector which would place it evenly in between the divided housing. I would like to run just one tial 44mil gate to keep the plumbing simple. would this setup give me boost creep at 15 psi? Name:  sst.JPG
Old Apr 8, 2009 | 01:21 PM
frenzyh22's Avatar
Not related but thought id add this in, a quality exhaust manifold requires and equally impressive intake. Name:  intake1.jpg
Old Apr 8, 2009 | 01:55 PM
ScorpionT's Avatar
Earl, if you need one shoot me a PM.
Frenzy, are you sure its divided? I checked their website and it doesnt mention that about the manifold. If it is, they went with the budget/simple style. You dont need two WGs, but you have better boost control and dont get cross-talk between sides of the manifold.
Old Apr 8, 2009 | 02:54 PM
TheShodan's Avatar
Moderator
No. one will be fine. It is a divided manifold. nothing more. as long as the placement of the wastegate is in the correct spot.
bigG
Mar 3, 2010 10:46 AM
9civichatch3
Sep 20, 2006 02:50 PM
jfoster
Mar 19, 2004 07:14 PM
EF'n
Apr 6, 2003 03:27 PM
