Throwout Bearing
Old Apr 8, 2009 | 06:30 AM
EJ6 BoOsT's Avatar
Default Throwout Bearing
Alright guys i need advice. I have a 95 integra gsr. about a month ago i dropped my tranny and put in a stock clutch... now everytime i step on clutch i hear a scrathin noise... most likely its because i didnt change my throwout bearing...can i drive the car like that with the bad throwout bearing or should i change it asap....i want to know because i need to drive the car already but i dnt want to mess it up my tranny.....so can i drive the car??
Old Apr 8, 2009 | 06:39 AM
Schister66's Avatar
Man U FTW
Default Re: Throwout Bearing
A bad throwout bearing (TOB) is more an annoyance than anything. It only contacts the shift fork and the fingers on the clutch. Your bad TOB doesn't come into any contact with the internal workings of the transmission; therefore, a bad TOB can't actually cause any problems with the tranny. It can however be very annoying when worn. The worst i could see it doing is scratching the shift fork and PP fingers up....I would change it eventually, but it isn't going to hurt anything for a long time...
Do a little research on the TOB and see what it is and does. That may give you a little more peace of mind that you're not ruining anything. Basically all it is, is a 2-piece cylinder with a set of ball bearings in between the two halves. This allows one section to be stationary with the clutch fork and the other side to rotate with the pressure plate. Simple piece, but gives a grown man the shivvers when its bad...
Old Apr 8, 2009 | 07:03 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
But if it grenades, you'll be stuck until you change it.
Old Apr 8, 2009 | 07:11 AM
Top Speed's Avatar
I agree
Old Apr 8, 2009 | 07:15 AM
projectr's Avatar
ive been driving on a bad throw out bearing for a few months now and its ok even it makes a nasty sound.now my main input shaft bearing is going bad.
jose_germanDC4
Dec 28, 2010 09:43 PM
watsvtecEK
Nov 26, 2005 10:20 AM
siregcivic
Aug 7, 2005 02:01 AM
Slow_Boy
Jan 14, 2004 04:44 PM
AzntaggeR
Feb 18, 2003 06:01 PM
