wiring problem
i have a 89 civic hatch and i put a 90-91 si cluster in i went over the wiring about 10 times now it was working perfectly fine and then when i was driving i shifted into 3rd at the rev limiter and my fuse blew for my turn signals now my turnsignals ,coolant gauge ,fuel gauge dont work or any of the cluster functions and when i put a new fuse in as soon as i turn the key on the fuse blows instintly does anyone know what could be making this happen?
i rechecked my wiring again and everything is in the right spot nothing is touching so its not at the cluster when i pulled the fuse i checked witch side had power. the top part had power and the bottom did not
ok today i took the tach wire out i put a new fuse in and it was working for about a half hour and then the fuse popped out of no where i didnt touch anything and it just went
I FIXED IT There Was a yellow wire that went into 2 wires and it didnt have any electrical tape on it and it was grounding out i tapped it up and everything works mint now
92hatch_cx-t
Jun 22, 2007 06:08 PM
EKstasy
Jun 18, 2006 12:32 PM
