nothing in the cluster working, except the back lighting. NEED HELP!
Please help us out need to get this figured out the speedo dosent work and dosent the tach. The e-brake light out, srs, check engine, I filled up the tank today and it has 3/4 tank left. It just all of a sudden did this the gas meter is funny to. Wiring messed up some relay/fuse and ideas will be greatly appreactated.
Have u ever messed with the wiring of your cluster? ifnot then more than likely it's the fuse, check your fuses one by one and replace them all fresh and new, if that does not work, check behind the gauge cluster and see if anything may have become loose, and make sure u put it back together properly.
If i had to make a call, i'd say fuse tho, so check that? what ek or ej?
Re: (VtecHusker)
kinda figured it out by checking all of the fuses. It was the "backlight" fuse that went out. But when you turn the signals on it just shorts and blows that fuse again. Any ideas of where to look for that problem?
ryu360
05-20-2010 08:06 PM
honda_conversion
06-22-2007 11:31 PM
