update on what I thought was a bent hub/ not a bent hub
Old Aug 14, 2002 | 05:14 PM
slowassR's Avatar
Default update on what I thought was a bent hub/ not a bent hub
Yup curbed my rim and thought I bent my hubhttps://honda-tech.com/zerothread?id=251540
That's not the case. After a closer look the hub is fine. What appears to be bent is, what I think is called, the rear radius arm. Its the thing that stick off the rotor.
I do have a question if any one knows the answer? Is the "rear radius arm" unique to a type R or can I pull one of a gsr?
[Modified by slowassR, 9:26 PM 8/14/2002]
Old Aug 14, 2002 | 05:16 PM
Comp97GSR's Avatar
Default Re: update on what I thought was a bent hub/ not a bent hub (slowassR)
I believe it is unique, and if it isn't just hope everything else is straight and swap it.
Old Aug 14, 2002 | 05:29 PM
migs's Avatar
Default Re: update on what I thought was a bent hub/ not a bent hub (Comp97GSR)
AKA Trailing arm
I wouldnt be TOO concerned about your chassis being tweaked. Those arms have should have a threshold before it starts manglin the chassis. Make sense?
Old Aug 14, 2002 | 06:26 PM
Tweakmeister's Avatar
Default Re: update on what I thought was a bent hub/ not a bent hub (Migs)
geez...
WHAT WERE YOU DOING !!!!
you could drive an ITR off a cliff and not bend one of those. I'm impressed Atleast it isn't something more serious...or complex.
Old Aug 14, 2002 | 06:28 PM
Hooch'n's Avatar
Default Re: update on what I thought was a bent hub/ not a bent hub (Tweakmeister)
Old Aug 14, 2002 | 06:57 PM
Warren's Avatar
Wrong-Way Wang
lol, if you smacked it hard enough to bend the trailing arm, you better replace the hub too.
About the only thing you'll want to keep from the old trailing arm are the brakes and maybe the upper control arm if that's not tweaked too.
Check to see if it aligns correctly after replacement.
Warren
Old Aug 14, 2002 | 07:01 PM
baonest's Avatar
Default Re: update on what I thought was a bent hub/ not a bent hub (Warren)
u can prolly even pull one off of an LS.. saves u money.. not 100% tho. but since its a ITR id go with either ITR or GSR
Old Aug 15, 2002 | 12:45 PM
slowassR's Avatar
Default Re: update on what I thought was a bent hub/ not a bent hub (baonest)
Can anyone recommend a place to pick up a trailing arm and maybe hub too?
Old Aug 15, 2002 | 12:54 PM
RTW DC2R's Avatar
Is it possible to straighten the trailing arm out?
Old Aug 15, 2002 | 12:57 PM
Anderson's Avatar
Acura parts.
good luck, that happen to me 2 but it's all better now.
Old Aug 15, 2002 | 01:09 PM
slowassR's Avatar
Default Re: update on what I thought was a bent hub/ not a bent hub (Anderson)
It may be but I would rather get a new one.
Acura parts.
How much did it cost for you to fix it?
Old Aug 15, 2002 | 01:53 PM
RTW DC2R's Avatar
here ya go...the picture on the page doesnt work for some reason so ill just post the link, but it does have the prices listed if you were to buy the parts from Acura. If you are gonna get a new one from Acura, contact the guys in Black R's sig. They will help you out.
http://www.acuraautomotiveparts.net/...REAR+LOWER+ARM
Old Aug 15, 2002 | 01:56 PM
jeff652's Avatar
haha nice pic. Looks a lot like mine ;-):
Anyways, the rubber on the ITR trailing arm is different from the other not R models. Otherwise I'd say just get a Civic trailing arm for free, swap the spindle over and get a new Hub. Total cost, less than $100 . . . .
Jeff
Old Aug 15, 2002 | 02:06 PM
slowassR's Avatar
Default Re: update on what I thought was a bent hub/ not a bent hub (jeff652)
Thanks RTW DC2!
Jeff
Ok thanks so no go on a gsr one. Thanks
rick_rabies
Sep 17, 2010 03:58 AM
SE7EN3S
14
Oct 23, 2005 06:16 PM
unknown0001
Aug 30, 2005 04:32 PM
slowassR
Aug 16, 2002 01:41 PM
