pr4-A61 LS ECU??? What OBD is it? Auto or Manual?
Old Apr 5, 2009 | 09:57 AM
kcvi3tstyl3's Avatar
Default pr4-A61 LS ECU??? What OBD is it? Auto or Manual?
I have done a lot of research and have not found a solid answer for a pr4-a61 ecu. I know that it is an LS ecu, but I dont know what OBD it is and if its an Automatic or manual ecu
thanks in advance for helping and reading this post.
EDIT: So now that I have found out that it is an OBD1 LS automatic edu, will it work in a 5 speed car, or what will it do to the 5 speed car?
Old Apr 5, 2009 | 01:47 PM
Default Re: pr4-A61 LS ECU??? What OBD is it? Auto or Manual?
ANybody?
Old Apr 5, 2009 | 01:51 PM
jcdimvic's Avatar
cant answer the auto or manual for you but as for the OBD, look at the plugs.
OBD0 will have a goofy looking green one on it and OBD 1 will have all grey ones.OBD 0 will have a little clearish red circle on the cover so you can check your codes also.
Old Apr 5, 2009 | 02:49 PM
TylerLorenz's Avatar
OBD-0 A61 is probably, manual.
Old Apr 6, 2009 | 11:14 AM
so is it an auto or manual? obd1 or obd0?
Old Apr 6, 2009 | 11:22 AM
NOFX's Avatar
H-T White Ops
37820-PR4-A61 is '92-'93 Integra GS / LS / RS automatic ECU.
Old Apr 6, 2009 | 11:33 AM
Thanks A lot to u^^. So now that I have found out that it is an OBD1 LS automatic edu, will it work in a 5 speed car, or what will it do to the 5 speed car?
Old Apr 7, 2009 | 08:15 AM
jcdimvic's Avatar
should work find in your car will throw a check engine though. find someone around u that has some experience with ecu's. I dont have an open ecu in front of me but i think that it is RP17 and you move it to RP19, cant remeber for sure, do some searches online u can find a way to convert it.
94DCTeg
Nov 26, 2008 12:08 PM
projectTeG
Dec 20, 2005 04:23 PM
DaX
May 20, 2005 11:22 AM
