Lost Speedo And Vtec
Old Apr 5, 2009 | 09:16 AM
snowskater34's Avatar
Default Lost Speedo And Vtec
well story is i was driving down to highway shifted into 4th hit vtec speedo stopped working and so did vtec. Seems to be blowing the number 15 fuse under the dash? Also the lights got really dim and that battery went dead? also throwing a p0135 p0141 and ap0500 now. so i just threw a 30 amp fuse in there cause the 7.5 kept blowing and now the speedo started working? what the hell is going on.
Old Apr 5, 2009 | 07:05 PM
Default Re: Lost Speedo And Vtec
Old Apr 5, 2009 | 07:33 PM
Former User's Avatar
Read this TSB.
You have a short in the main wire harness at the rear side of the intake manifold. This is a common problem. The TSB tells you have to identify and fix the problem.
Old Apr 5, 2009 | 08:14 PM
thank you very much...im going to try this tomorrow.
Old Apr 6, 2009 | 08:14 AM
kp's Avatar
kp
NEVER do this again. You're asking for a car fire.
Old Apr 6, 2009 | 08:21 AM
DCSportEJ1Civic's Avatar
x2, your going to be replacing a lot more than a few wire if you smoke your dash harness or something else. theres a reason why fuses have different amperage ratings.
Old Apr 8, 2009 | 08:50 PM
oh damn. i guess i need to change it back to the right fuse. but the 30 amp did work i guess just cause it can handle more amps and it just masked my problem. thanks guys for that never even thought about it.
Old Apr 9, 2009 | 06:56 AM
kp's Avatar
kp
Yeah, it will work and it may fix your problem but it won't blow like a 7.5A fuse. The 30A would just heat up and eventually make bad things happen.
Old Apr 14, 2009 | 06:19 PM
well i think i solved it...it was my o2 sensor the wires where touching the axle shaft and rubbed all te wires bare i guess there for causing a short and blowing the fuse..
jdmsleeper12
Apr 8, 2010 07:29 AM
97VtecIN
Dec 1, 2004 07:07 PM
avividmemory
Jun 14, 2003 10:39 AM
