auto - manual swap? EG stuff will work on EK???
so im doing to be doing an auto to manual swap on my Ek.
ive heard that EVERYTHING that i will need i can get from any 92-00 civics.
yet i have also heard that only 96-00 will only work
so Clutch master cylinder, hard lines, 3 padals with firewall attachment, shift linkage, etc
i've searched and i have only found that for sure the shift linkage from a 92-95 will work on my 96.
but im not sure about the pedals, hard lines, etc.
any1 know?
any1 know?
every thing can come from a 92 - 95 for the y\trani if y ouy get a 92 u will have 2 get the shift linkage for that transmission but fr the peadls you can get pedals from any kinda honda you could get pedals from a del sol and civic and for the master cylnder and line i would got to the junk yard and just get the master cylinder and lines also get he pedals from the junkyard
and im planning on getting a manual tranny from a d16y8.
and as i said, the shift linkage works from 92-00
The shift linkage definately works
The mounts must come from a '96 - '00 civic (front lower transmission bracket can come from a '92 - '95 civic though)
Rear T-bracket can be reused, automatic and manual versions are identical
clutch pedal definately works, same honda part number, the brake and gas pedals have different part numbers and I don't know if they are interchangeable or not, or what the difference is.
Clutch line must come from a '96 - '00, its completely different from '92 - '95 civic
thank you sir.
so i will get the shift linkage and clutch pedal from a 92-95 and the rest i will get from a 96-00
and would it be better just to buy a new clutch master cylinder?
approx. how long will the swap take?
i found a thread on here that gives me the complete how-to with pics and everything.
so im wondering how long will it take?
any1 know?
93eg2james
Aug 18, 2006 08:55 PM
deeeffache
Sep 10, 2002 02:29 AM
