Will '94 GS-R rear disc brake system fit on EG?
Old Apr 5, 2009 | 08:02 AM
coffee_junkee's Avatar
Default Will '94 GS-R rear disc brake system fit on EG?
I have a 4dr GSR donor car and was curious if the 4dr brakes and trailing arms will fit on a 93 hatch?
Thanks!
Old Apr 5, 2009 | 08:30 AM
eK24monster's Avatar
Default Re: Will '94 GS-R rear disc brake system fit on EG?
Yes.
Old Apr 5, 2009 | 09:31 AM
prettyinpink_EG's Avatar
yes
Old Apr 5, 2009 | 10:27 AM
civicsmoke's Avatar
yes it will, but you dont need to swap the whole trailing arm. just the spindles, its a 24 mm bolt and 4 torx bolts on the back. unless the bushing are better on the gsr trailing arms. good luck
Old Apr 5, 2009 | 10:31 AM
jgh22's Avatar
Old Apr 5, 2009 | 12:53 PM
BrizzlEK's Avatar
compared to the six bolts for the trailing arm its not that different, personally for me the trailing arm swap was much easier than the spindle because you have to take off the drum and everything to get to the spindle.
Paul1985
Dec 7, 2006 02:49 PM
huge230
Dec 1, 2005 02:55 PM
ArtNerd
Aug 26, 2005 09:33 PM
edo3276
Jun 17, 2004 05:56 PM
HYBRIDHATCH92
Apr 23, 2002 02:40 PM
