93 civic lx sedan with b16a swap no spark!!!
The car ran fine for years and then one day would not start. Replace dizzy with new one and checked fuses and still no spark. I rarely have problems like this Im a honda tech and take care of a lot of insane problems but this one is a nightmare! Checked for continuity between all wires and it seems as power is present at the two prong connector on the black and yellow wire prong side only the blue one does not and also traced back to the starter signal fuse under the dash there is no power there with the key on and while rotating the engine!!! Need help any and all suggestions are appreciated!
I bumped the key like twenty times plus and couldnt really tell cuz the dam fan noise cancels everything out but regardless without spark that gas wouldnt ignite but you know what you could be right that relay could or is the cause of no continuity to the starter signal fuse Im gona check it out! Keep them coming any and all help is better than nothing at all!
your replacement dizzy could be bad too, most places sell you a reman'd dizzy and ive had problems in the past with the replaced dizzy failing within a few days
