dumb ek swap questions
sorry i know these are stupid questions and i should know the answers i just wanna double check before i throw this motor in the car
putting a b16 into a 97 civic coupe
will dc axles and shift linkage work?
will the rear motor mount bracket off a b16a from an ef or a dc rear bracket?
will single cam injectors work?
will the single cam drivers side motor mount bracket that bolts to motor work?
will dc axles and shift linkage work? yes
will the rear motor mount bracket off a b16a from an ef or a dc rear bracket? you need 99-00 civic si bracket
will single cam injectors work? yes
will the single cam drivers side motor mount bracket that bolts to motor work? you will need 99-00 si mount bracket (the one that bolts up to the block) all other mounts will be stock
sanegb16
Sep 5, 2007 01:41 PM
deviant1
Mar 21, 2003 11:03 PM
