Tranny Question....
Old Apr 4, 2009 | 04:44 PM
VietSpeed's Avatar
Default Tranny Question....
In my ITR my tranny is a S4C tranny and it also has S4 printed on it. Do you guys know what tranny this came exactly? And is it equip with LSD or is it optional LSD.
Old Apr 10, 2009 | 04:42 PM
VietSpeed's Avatar
Default Re: Tranny Question....
Anyone?.....
Old Apr 10, 2009 | 08:40 PM
audiko4's Avatar
S4C is the stamping for a b16a or b16b transmission case
Old Apr 19, 2009 | 12:23 PM
VietSpeed's Avatar
Does anyone know if this tranny could be a Civic Type R tranny?
Old Apr 19, 2009 | 12:43 PM
racebum's Avatar
i think the ctr trannies have R4 LSD in black ink just like the ITR has J4D LSD. you should be able to look through the axle hole and see what diff is in there. the LSD is hollow, as in no bar
Old Apr 19, 2009 | 05:27 PM
98DC2R's Avatar
It sounds like a 99-00 civic SI b16 tranny. Does it have a vin plate on it?
Old Apr 20, 2009 | 04:02 PM
VietSpeed's Avatar
Yes, and it's vins from an integra. that is why i'm kinda confused. I know it looks like a civic tranny but could it be a CTR tranny?
Old Apr 21, 2009 | 06:08 AM
98DC2R's Avatar
Pm me the vin and I can tell you what it is. CTR tranny's never had a vin plate.
Old Apr 21, 2009 | 03:57 PM
jdm_94's Avatar
Here we have an hybrid tranny!!! S4C just for Civic not for Integra.
Old Apr 30, 2009 | 04:26 PM
VietSpeed's Avatar
So.... No one knows for sure what type of tranny this is?
Old May 1, 2009 | 07:51 AM
sackdz's Avatar
measure the ratios and find out!
Old May 2, 2009 | 11:47 AM
VietSpeed's Avatar
And how would I do that? I really don't want to rip my tranny out.
Old May 4, 2009 | 10:23 AM
sackdz's Avatar
Its a pain in the ***, but I bet you can do it in like 30 minutes, if you had a friend.
-Take out your spark plugs
-Put the car in each gear and spin the crank a set # of times, like 100 rotations, and keep track of how many times the wheel rotates. Make sure you count partial rotations. Accuracy is important
-Divide crank rotations by wheel rotations, and that will give you your gear ratios multiplied by your final drive ratio
-Divide all the ratios by the common FD ratios (4.40, 4.785, 4.929, etc) to give your 1-5 gear ratio for each possible final drive.
-Reference something like this (no guarantee on accuracy of this particular dataset): http://hondaswap.com/reference-mater...n-specs-29132/
and you should match one of those trannies pretty close!
Obviously, it would be much easier with a friend to count wheel while you count crank, and keep a spreadsheet.
If you had a very stable idle and accurate (digital) RPM reading, you can do the same thing by idling the car in gear on jackstands and timing (stopwatch) how long it takes to go a mile on the trip
XKINGX
May 14, 2009 07:42 PM
blade0314
Apr 10, 2008 01:21 PM
vtec25
14
Mar 14, 2006 08:26 PM
B18C-RnVA
Sep 21, 2001 08:08 AM
