Does rebuilding a turbo end shaft play?
Old Apr 4, 2009 | 01:54 PM
tkda's Avatar
Default Does rebuilding a turbo end shaft play?
its a tdo5h
it has side to side and in and out.
Old Apr 4, 2009 | 03:16 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Does rebuilding a turbo end shaft play?
in and out is bad. that means the thrust bearing is gone.
you will always have a little side to side ont a journal bearing turbo. until it has oil pressure to suspend the shaft.
Old Apr 4, 2009 | 05:33 PM
tkda's Avatar
right, in and out is bad. but i belive the thrust bearing is in this kit correct?
http://cgi.ebay.com/ebaymotors/TURBO...Q5fAccessories
so it would end shaft play side to side and in and out, correct?
thanks again for the help, just want to cover the bases before i pick up this turbo.
Old Apr 4, 2009 | 06:55 PM
303h22's Avatar
x3 in and out bad
Old Apr 4, 2009 | 07:32 PM
b20beast83's Avatar
you can talk to the guys at gpopshop.com
Old Apr 5, 2009 | 02:10 AM
91jdmhatchback's Avatar
the guys at g pop shop are great, i have had a turbo rebuilt buy them one of the worst i had seen it had massive shaft play and it came back and looked brand new.
worked great
highroller54
May 18, 2009 03:46 PM
hayn
Nov 23, 2003 07:39 AM
cock head
Jan 18, 2003 05:55 PM
John
Oct 23, 2001 07:16 PM
