Compression required for a Breather kit?
Old Apr 4, 2009 | 10:48 AM
USDM-EK4*'s Avatar
Default Compression required for a Breather kit?
I'm in the process of collecting parts for my build. Getting a breather kit was on my list, but is it nessary for a 11.3.1-11.5.1 compression ratio?
Old Apr 4, 2009 | 11:11 AM
onefstek's Avatar
Default Re: Compression required for a Breather kit?
Its not the cr what determines if you need a breather kit or not.
Old Apr 4, 2009 | 12:07 PM
Farmer89511's Avatar
it has to deal with the crank case pressure right?
Old Apr 4, 2009 | 12:29 PM
98vtec's Avatar
moderator emeritus
yes. It gives the pressure acting against the piston on its way to BDC a place to go instead of being bottle up to a certain pressure number to open the PCV. This relief of pressure on the pistons and rings frees up HP, theoretically.
I believe there is a more of a need with these kits when you have a r/s that is low and accelerates away from TDC faster than a long rod. The more it accelerates, the more pressure it builds as a force against the direction of the pistons. But thats just my opinion.
Old Apr 4, 2009 | 12:33 PM
Oh okay so that breather kit helps out the PCV valve out with doing its job?
Old Apr 4, 2009 | 12:36 PM
98vtec's Avatar
moderator emeritus
you are bypassing the PCV when you run a crankcase ventilation setup.
Old Apr 4, 2009 | 12:44 PM
USDM-EK4*'s Avatar
I always thought the higher the compression the more crankcase pressure it builds up?
Old Apr 4, 2009 | 12:46 PM
00Red_SiR's Avatar
All Motor Mentor
no. Compression in the combustion chamber does not equal pressure in the crankcase unless you have very poor ring seal. If that's the case, a breather kit is hardly the solution to the problem.
Old Apr 4, 2009 | 12:57 PM
USDM-EK4*'s Avatar
Oh i see. Thanks for clearing that up for me.
hybrid_vtec
23
Mar 14, 2005 09:20 PM
pwr2lbs
20
Nov 30, 2004 03:45 PM
AgentJam
Sep 30, 2004 07:28 PM
85mm LsVTEC
34
Jan 25, 2004 04:56 PM
lke2drvgsr
Jan 11, 2004 10:02 AM
