W t h!!! Ek won't start
Old Apr 4, 2009 | 10:08 AM
o0Riffraff0o's Avatar
Default W t h!!! Ek won't start
my friend was driving my 98 ek ex on the freeway "he says"....
well "apparently" he was floating along and "-something made a CLINK CLINK CLINK sound, and then fell off". shortly after that the car just "diedhttp://images.ibsrv.net/ibsrv/res/src:honda-tech.com/get//images/smilies/thud.gif."
iv checked all the belts- all there
iv checked all the fuses- all good
and all the underhood relays look damn near brand new
everything works- roof, locks, windows, lights, gauges, sig jack, eveything
but it won't turn over... i turn the key, i get one click and then nothing....
i know its a power issue... but what could have "fallen off" to cause the car to just "die" and not even turn over
HELP ME GOD DAMN IT!!!... IF I HAVE TO DRIVE MY AUTOMATIC FOR ANOTHER DAY IM GONNA BIT ONE OF MY FINGERS OFF... IT SEAMS LIKE AS SOON AS MY REAL CAR IS DOWN- EVERYONE WANTS TO RACE ME ALL OF A SUDDEN!!!! AND TO WAVE THEM OFF IS EATING AWAY AT MY SOULhttp://images.ibsrv.net/ibsrv/res/src:honda-tech.com/get//images/smilies/mad.gif
Old Apr 4, 2009 | 12:56 PM
autoponicz's Avatar
Default Re: W t h!!! Ek won't start
have you checked under the car?
Old Apr 4, 2009 | 01:02 PM
ekmushi_mushi's Avatar
http://www.azht.net/forum/showthread.php?t=93306
alot of people have the same problem here check hat out
Old Apr 4, 2009 | 02:25 PM
StreetRacinThug's Avatar
Aside from the clinking sound, no crank just clicking means the starter is bad/frozen/locked/jammed. Might be able to hit it a couple times or just replace it.
Old Apr 4, 2009 | 02:55 PM
Redbone's Avatar
i say check your grounds because i dont know why something would have stopped the car from running while he was driving. yet another reason not to loan your car to anyone.
Old Apr 4, 2009 | 05:00 PM
R666_EK's Avatar
You're friend is probably lying. Without thinking about the noise and something falling of, it sounds just like a bad starter. Have someone crank it while tapping the starter. See what happens.
Old Apr 4, 2009 | 05:52 PM
Former User's Avatar
Is there battery voltage at the large Blk wire connected to the starter?
Old Apr 4, 2009 | 05:57 PM
hexjunkie's Avatar
Sorry for your loss, but your description just made my day.
I would go with ground, there are very few things that will stop a motor from running once it gets going.
Help Desk check list by numbers:
Is there gas in the car
Is the battery charged
Is there fuel getting to the cylinders
Is there air getting to the cylinders
Is the starter turning over if there is a charge to the battery
Is there something obstructing the flywheel from turning from the starter
from there it gets more complicated
Old Apr 5, 2009 | 02:48 PM
i took the starter out this morning... and had it tested at kragen...
stater is good
now im baffled......
Old Apr 5, 2009 | 02:51 PM
R666_EK's Avatar
Timing belt?
Old Apr 5, 2009 | 03:28 PM
The_Honda_Guy's Avatar
Timing belt I bet, especially if he was driving, made a sound, then wouldn't start again. I'm sure the clink sound were the pistons giving the valves the finger.
Old Apr 5, 2009 | 03:35 PM
en00be's Avatar
hmm
Old Apr 5, 2009 | 03:39 PM
Redbone's Avatar
maybe ur motor is fugged FTL
Old Apr 5, 2009 | 05:19 PM
maybe your face is fugged >
... but yea, i checked all the basics.... belts, fuses, relays, blugs, starter... am i missing anything?
Old Apr 5, 2009 | 06:30 PM
RHD-EG2's Avatar
might have jumped time. Check the timing.
Old Apr 5, 2009 | 06:33 PM
team_lunatics's Avatar
yo, does your fuel pump still activate when you turn your key (II)....
Old Apr 5, 2009 | 06:34 PM
R666_EK's Avatar
It would still crank and most likely start. The starter was engaging, but couldnt turn the motor over.
Old Apr 5, 2009 | 06:40 PM
RHD-EG2's Avatar
Yeah but if it jumped time while he was driving due to the timing belt stretching and what-not then its possible that its locked up dogg. Check timing marks.
Old Apr 6, 2009 | 01:29 PM
yep... everything powers on like normal
Old Apr 6, 2009 | 06:17 PM
RHD-EG2's Avatar
I still think it jumped time and locked up. I hope not for your sake but thats what Id bet on.
Old Apr 6, 2009 | 06:46 PM
R666_EK's Avatar
That just doesn't happen. If it jumped time it would run like ****. It won't lock up. Think!
edit: I take that back. If it SEVERELY jumps time it could. But rare. It more than likely broke.
Old Apr 7, 2009 | 12:42 PM
i am begining to think a rod broke... he said he heard a clink clink clink... and for it not to turn over out of the blue it kind of adds up.....
i haven't push started it yet though... ish is heavy
Old Apr 17, 2009 | 01:21 PM
Ok heeeeelp.... I checked out the motor..... Rods 3 & 4 are sticking out of the block FROM BOTH SIDES... broken shards everywhere.....
I just picked up a new block and i dropped the motor out already... I started all this at 6am of course
will i have the tranny off... But i need to know the torque pressure for the clutch and plat and stufff pppllleeeeaaassseee... This is the only part i don't know and its 2:30 and i have untill 6 to get the motor in the car
ppppllleeeeaaasssseee hhheeeeellllpppppp... Im in my garage right now covered in tranny fluid oil and coolant in a tight race against time!!!!
Old Apr 17, 2009 | 01:30 PM
EG6KILIN's Avatar
well what you need help with what kind of motor do you have?
Old Apr 17, 2009 | 01:32 PM
just an old booboobbutt d16y7 block and a y8 tranny........ AHHH IM BEEING ATTACKED BY BEE'S AND WHASP'S HURRY
Stonage07
Jul 1, 2017 05:25 AM
jpo20
Mar 16, 2010 07:06 PM
Tony Starks
Sep 20, 2003 07:34 AM
