Wacky tachometer
Old Apr 3, 2009 | 09:22 PM
garykf16's Avatar
Default Wacky tachometer
The tachometer on my '95 Civic has been acting strangely. At idle, it may indicate a reading anywhere from 800-2000 rpm. It is not fluctuating, these are steady readings when it is idling, which has always been a steady 800 rpm before this started happening. The engine is not fast idling, this occurs whether the motor is warm or cold. You do get the normal fast idle during a cold start for a minute or two until the motor warms up. When accelerating, the tach will sometimes hesitates, it does not smoothly follow the engine speed always. The engine runs and idles very steady, does not miss or hesitate, just the tach is not responding and indicating normally. It's at 188,600 miles, good gas mileage, not burning oil or smoking. What should I check, where is the tach sensor pickup getting its signal from the engine? The motor is a D15B7, non-VTEC, '95 Civic LX 4 dr automatic.
Old Apr 3, 2009 | 09:31 PM
Former User's Avatar
Default Re: Wacky tachometer
The tach signal comes from the blue wire attached to the igniter unit in the distributor. Check whether the connection is corroded or loose. In some cases, the fix is to replace the igniter unit itself. Another possibility is that the tach itself is bad. To test, hook up a tach to the connector near the clutch master cylinder to see whether or not it reads correctly.
Old Apr 3, 2009 | 09:44 PM
v!taminb16's Avatar
i have a questin also on certain occasions when i engage vtec after like 6k my tach will begin to dance but as soon as i shift into the next gear it is fine im thinking maybe my tach is bad
Old Apr 3, 2009 | 09:49 PM
What year Civic?
Old Apr 3, 2009 | 09:55 PM
v!taminb16's Avatar
t's a 96 but my cluster is out of an automatic SiR it has a tach and everything
here is a picture
Old Apr 3, 2009 | 10:00 PM
Yeah, what I said in post #2 also pertains to your Civic, although the blue wire is attached to the ICM (=igniter unit) in your distributor.
Steve-T
Aug 14, 2017 04:36 PM
Spins
Apr 18, 2005 02:01 PM
IDI2IEIAIVIS
Feb 22, 2003 04:07 PM
95accordracer
Dec 26, 2002 07:13 PM
