Honda S2000 Honda S2000
S2000 Engine Temperature PHAIL
Old Apr 3, 2009 | 09:38 AM
Undisputed18's Avatar
Default S2000 Engine Temperature PHAIL
Ok... so I have an 03 s2000 honda and well I just put new valves in and everything. We had 1 problem with trying to find a sensor connector to the engine temperature which is located on the very back of the engine where the windshield is. We ghetto'd it out a little just to see if the v-tech kicks in because it never used to kick in until we plugged the wires in. The wires have 2 pins which 1 wire is green and the other red, we connected them to where they are supposed to go without the sensor connector because it came off when we ripped apart the head. Now it was working fine just yesterday until all of a sudden I left my car idling and when I got back in the car the engine temperature gauge was almost at red!!! I was like WTF mayte... so anywayz I was looking into it and I saw my fan wasn't working... I checked all the connections that led to the fan and they looked fine... I checked the fuse and IT looked fine wasn't burnt or anything... I was reading up on a couple of forums that people had the same problems and they said something about a 12-volt switch which i dont know what that is... im kind of a beginner with cars. Can anyone please help?
Old Apr 3, 2009 | 10:58 AM
fast95se's Avatar
Default Re: S2000 Engine Temperature PHAIL
Originally Posted by Undisputed18
...we ripped apart the head.
I don't think these two phrases go together well, unless the other part of we is someone with mechanical know-how.
Old Apr 3, 2009 | 11:23 AM
Yeah he is he's the one that helped me put my car back together. One of the valve tips was cut off like if you cut paper with siscors... but we got my car working again... Im just having a problem with my fan.
Old Apr 3, 2009 | 07:46 PM
kingdingaling's Avatar
just hook up a wall fan n call it a day... remember to leave it on high
Old Apr 4, 2009 | 09:35 AM
S2KFTW's Avatar
ah honda-tech is so helpful
if you're going to work on the car yourself, do yourself a favor and get a honda shop manual. the troubleshooting flowcharts will save you a ton of time and aggravation. either get a real one from Helm or there's a million places to get bootleg PDF versions, I like having a printed copy personally.
http://www.helminc.com/helm/homepage.asp
Old Apr 4, 2009 | 11:07 AM
I do have a honda manual thats how we took off the head and everything... but anywayz you guys still havn't answered my question WHAT TO DO!!!!! i switched the fan switch and still doesn't turn on maybe it might be the thermostat?
Old Apr 5, 2009 | 06:54 AM
tech7427's Avatar
you probably have air in the cooling system. hence the fan not working. do you have heat?
Old Apr 5, 2009 | 01:40 PM
S2KFTW's Avatar
like tech said, make sure there's no air in the system.
Old Apr 5, 2009 | 04:48 PM
White Smoke's Avatar
i my honda
Global Mod
There is a temp sensor for the gauge and ecu (vtec) and a temp switch for the fan. If you have the Helms just look up the fan trouble shooting and it will walk you through proper tests. Thermostat is proly not the problem. It's going to be air or the switch/switch connections itself.
Old Apr 5, 2009 | 05:52 PM
tech7427's Avatar
I'm still going with it air by the thermostat and in the heater core. Jack up the car and run the car with the cap off . Then put cap on, let it run, shut car off, unscrew bleeder valve on I'm and let air out. Start car with cap on, rev it to like 2K and try n get the coolant into the heater core. If u need to take the cap off the rear heater core line
Old Apr 5, 2009 | 09:14 PM
Driven's Avatar
you spelling "fail" with a "PH" to be either humoruous or hip/trendy.... is "fail".
Lsos
Honda S2000
27
May 22, 2011 01:04 PM
Ian.G
Honda S2000
Feb 17, 2011 09:39 AM
S2K NATE
Honda S2000
Apr 10, 2007 10:17 AM
magic15x
Honda S2000
29
Oct 31, 2004 05:46 PM
IIBPIIprelude
Honda S2000
Feb 7, 2004 08:52 AM
