si hatch crazy problems
Old Apr 3, 2009 | 09:15 AM
fatt6903's Avatar
Default si hatch crazy problems
im new to this site and ive been outta honda for 4 years..i recently picked up a 93 si hatch it had a b18b in it till i spun the #4 rod bearing soo i swaped the d16z6 back into it well every since then im now having a nasty pop noise coming from the rf wheel area when i break and when i take off..soo today i replaced the wheel bearing and hit all the suspenion parts with the impact to see if that would help but no fix it still makes the pop or clunking noise...its not the cv axles there brand spankin new not remans.....im also getting a metal on metal thin grinding noise from the diff area of the tranny i think it could be the carrier bearings in the diff....if anyone might of had this problem please help
thanks
Old Apr 3, 2009 | 12:36 PM
DJStreetz's Avatar
Default Re: si hatch crazy problems
ball joint bro!
Old Apr 4, 2009 | 06:14 PM
fatt6903's Avatar
so i replaced the ball joints and tie rod ends and this **** still pops the same!!!!
Old Apr 4, 2009 | 07:17 PM
cloudconnected85's Avatar
sounds like an axel and did you replace the upper and lower ball joints? and autozone axels suck.
Old Apr 4, 2009 | 07:47 PM
DCSportEJ1Civic's Avatar
autozone axles do suck, ive snapped two of them. glad they warranty them. have you check motor mounts, brakes, ect?
Old Apr 4, 2009 | 09:09 PM
oh yeah slipped the torque mounts can do that. if they're busted fill em with 3m window weld. works wonders and is only 20
Old Apr 4, 2009 | 09:51 PM
daymkimchee's Avatar
the pop noise is probly from the clips missing in your brake pads
Old Apr 4, 2009 | 10:15 PM
waaBAAH's Avatar
si hatches had front link pins. front link pins can cause a clunk or pop
Old Apr 4, 2009 | 10:38 PM
08zx14's Avatar
^agree'd i had this issue and it was the sh*tty autozone axles i had put in.
Old Apr 5, 2009 | 04:06 AM
fatt6903's Avatar
i have gsp new axels from adavence auto parts, i replaced the lowers and theres no wheel movement or endplay nemore what are the front link pins??
Old Apr 5, 2009 | 04:09 AM
fatt6903's Avatar
its sounds like its in the rf but u can feel it under the passangers seat..ill check the brakes again but when i put the ball joints in all the clips where there
Old Apr 5, 2009 | 04:28 AM
Jimster480's Avatar
does it make that noise all the tiem?
Old Apr 5, 2009 | 06:38 AM
redline7070's Avatar
are the lca bolts tight
Old Apr 5, 2009 | 06:15 PM
fatt6903's Avatar
lcm bolts r tight as hell.....only makes the noise at take off and when i initanly brake
Old Apr 6, 2009 | 04:38 PM
fatt6903's Avatar
its got solid motor mounts and a k-sport 32way adjustable coilovers
Old Apr 6, 2009 | 05:28 PM
EK99hatch's Avatar
Si hatches came with a front swaybar didn't they? Check to make sure the swaybar is tight.
Old Apr 6, 2009 | 06:46 PM
fatt6903's Avatar
sway bar it tight
Old Apr 6, 2009 | 07:07 PM
instructor74's Avatar
okay check these things a bad shock or loose spring can cause a clunk. As already posted bad sway bar end links or loose worn rubber check the front lca mounting points for worn rubber bushings.
Old Apr 8, 2009 | 12:25 PM
fatt6903's Avatar
ok i fixed the problem thanks everyone... i took the front shocks out and re-adjusted them and swaped sides the noise went away
Ef Whore
34
Apr 15, 2010 11:53 PM
chirp the 1-2
Mar 2, 2006 10:24 AM
pdc125
Jul 27, 2005 07:27 AM
JDMstance99
Dec 25, 2004 03:00 AM
yusoslo
13
May 26, 2004 03:09 PM
