CEL Help
Old Apr 3, 2009 | 08:45 AM
eskimo10's Avatar
Default CEL Help
Hey guys, heres the story. I was driving around and popped a check engine light, got the codes read. They came up as: P0171 and P0170 (system to lean bank 1 and fuel trim malfunction bank 1). So my question is, could this be related to an o2 sensor going bad? Like would a bad o2 sensor make these CELs pop? (Bank one is where the o2 sensor is located in the header right?)
If not, what all should I start looking at as a cause?
Anyway, thanks for your help, any and all is welcome!!
Old Apr 3, 2009 | 02:14 PM
Former User's Avatar
Default Re: CEL Help
I would start by measuring the fuel pressure:
Old Apr 3, 2009 | 08:32 PM
eskimo10's Avatar
That looks like its out of some service manual. Is that something I can acquire?
Old Apr 3, 2009 | 08:48 PM
I PM'd you.
Old Apr 19, 2009 | 07:57 PM
r_Senik's Avatar
im having the same code too...it said check vacuum if theres a leak too..
but i have a 00 si with an ITR IM. and one of the hose i didnt need but i didnt plug it right properly..so im gonna check that first.
Old May 12, 2009 | 10:54 AM
eskimo10's Avatar
So, this is a bit old, but I hadn't had time to diagnose and work on my CEL. I went and got it read today at AutoZone and I had 3 codes: P0135, P0170, P0171.
Is it possible that P0135 (bad o2 sensor) could have caused the other two to start with??
Old May 12, 2009 | 10:57 AM
Yes, fixing P0135 may fix all three codes.
Old May 12, 2009 | 10:59 AM
eskimo10's Avatar
Hm, ok that will be my first priority. Now, the P0135 code didn't happen right away, its been a few months like this before I even pulled that code. Is that going to make a difference?
Old May 12, 2009 | 11:04 AM
It shouldn't matter.
Old May 12, 2009 | 11:21 AM
eskimo10's Avatar
Yea I have that manual, and I noticed that a bad o2 sensor is a common cause between the two, but I just didn't know if it would matter that it came later.
Also, on page 11-157 of that manual it shows how to test if the o2 sensor is bad, on the second step we're measuring for continuity between the battery and the connector. What does it mean by continuity. IE should it read a certain number of Ohms?
Old May 12, 2009 | 11:53 AM
Continuity means a reading of very little or no resistance (= ~0 Ohms).
Boosted97Ej8
12
Oct 8, 2012 12:04 PM
taterbug
Jan 1, 2009 04:01 AM
MakoE2
Sep 28, 2005 06:19 PM
Eclpze97
Mar 25, 2004 01:15 PM
96vteclude
Dec 21, 2002 04:39 PM
