need help how to change fuel pump!! asap track meet tomorrow
Old Apr 3, 2009 | 06:13 AM
EG6KILIN's Avatar
Default need help how to change fuel pump!! asap track meet tomorrow
my damn fuel pump gve up on me it wont power up my b18c1 an i have a track meet idk **** about fuel pump or electrical wiring if anyone know how can you help out thanks!
Old Apr 3, 2009 | 06:32 AM
superbean's Avatar
Default Re: need help how to change fuel pump!! asap track meet tomorrow
pull rear seat
the will be an oval cover, take the 4 screws off and slide it out of the way
Take the fittings off the pickup tubes for your fuel supply and return (WARNING, if there is fuel pressure still in the lines, it will spray everywhere), more than likely there wont be as it wasn't working
unhook the wiring to the pump
take the 6 or 8 bolts off the top of the picup and pull the whole assembly out
be careful not to hit it on anything so it doesn't know the strainer off or bend the fuel level sending unit
there will be a pump on the pickup. Unhook the power and ground wires from it and slide it out.
Put new pump in the same way.
Cheers
Old Apr 3, 2009 | 06:38 AM
EG6KILIN's Avatar
awsome man you f_ing rock now i will se what happens if not i will get back at you!
Old Apr 3, 2009 | 06:41 AM
superbean's Avatar
sounds good man, it's really easy.
I learned the whole fuel system real well when my main relay went out and i had to run a wire to the pump from the battery every time i had to drive it lol
Old Apr 3, 2009 | 06:57 AM
EG6KILIN's Avatar
wait are you for real so worst case i have to run a wire to the battery what wire is that
Old Apr 3, 2009 | 07:00 AM
SuperTuner12010's Avatar
Dont change the pump yet.
When you turn the car on, do you hear a click from under the dash by the door pillar? If not im sure its your main relay. Even if it does click, borrow a friends and try it...More than likely its your main relay. Fuel pumps dont go out very often...
Old Apr 3, 2009 | 07:12 AM
EG6KILIN's Avatar
well i do hear the clicking noise like when i turn the battery like a very little click...
Old Apr 3, 2009 | 07:25 AM
StreetRacin101's Avatar
This is what we were trying to explain to you in the other thread, EG6KILIN. You need to rule things out before switching out the fuel pump.
You could have...
Bad Fuses (Even just a loose contact on a fuse block)
Bad Wiring (Since you did a wire tuck)
Bad Fuel Pump
Bad ECU
Bad Main Relay
Old Apr 3, 2009 | 07:36 AM
EG6KILIN's Avatar
yeah your right i think it could be my wire tuck is there anyway i can directly connect the fuel pump to the battery
Old Apr 3, 2009 | 08:01 AM
EG6KILIN's Avatar
i mean slong as it work for one day its all good all i need it for one day
Splock
Jul 30, 2017 08:57 AM
NovaRex
Dec 4, 2015 05:10 PM
trevorjohn88ef
Jul 16, 2010 12:44 AM
eastbayg
Sep 15, 2008 06:48 PM
ill phil
Apr 23, 2003 11:58 PM
