Transmission problem again.
This is the 3rd time taking this tranny out. This time I think I've got it. We saw oil all over the seal on the engine side, which we are going to change this seal. Here's a question, should I change my clutch disc? About 6 months ago I took this transmission out and swaped a new clutch and flywheel on there. Recently, I ended up getting a used M2L5 for my f22b1 and my Clutch now has oil on it. Flywheel is probably going to need some resurfacing from the oil but do you think I should get another NEW Clutch or is there a way to clean the clutch that has the oil. That would suck if I gotta buy a new one if this stage 3 Clutchmasters is done.... Any suggestions?
Depends on the material. If you got oil on brake pads how'd you handle it?
Ceramic/Metallic/Kevlar/Organic will all act differently.
Personally, I'd think about weither or not I'd ever want to do this job again and if I didn't, I'd buy new and e-bay the old.
might want to inspect the engine for other leaking spots and if your milage is close enough do the t-belt and then when you put it all back together you will be good to go.
I got the Clutchmasters FX300. Has anyone tried to revive a clutch from oil contamination? I'm talking about not even having 2000 miles on it before my seal started leaking. Damn flywheel needs to get the disc replace. This sucks!!! If i try and buy the same setup again it will probably cost me 700.... I cant believe this ish!
preludeshdriver
Aug 26, 2005 09:27 PM
