Will an O2 sensor ment for a Civic SI work for an EX?
Old Apr 2, 2009 | 07:42 PM
ffspiel's Avatar
Default Will an O2 sensor ment for a Civic SI work for an EX?
Got a question that's way above my head... I need a tech that can answer this.
I'm changing out my upstream O2 sensor on my 99 Civic EX Vtech (D16y8) engine. I purchased an NGK sensor from a site, but suspect (thanks Lioness...) that it's the wrong sensor for the application. The one I purchased was a 24625, ment for the SI Civic (160 HP, 99-00, I believe), the one I suspect that I should have bought was 24631.
Q: Will the 24625 work for my application or do I need to order the above?
Thanks.... rob
Old Apr 2, 2009 | 09:26 PM
zimsplat's Avatar
Default Re: Will an O2 sensor ment for a Civic SI work for an EX?
if the plug matches up as far as i know they should be the same.
Old Apr 3, 2009 | 06:15 AM
ffspiel's Avatar
Thanks, Zim...
thereisacat
Feb 18, 2017 09:08 AM
N1YDP
15
Feb 22, 2015 12:12 PM
blackccoupe
Dec 18, 2008 06:41 PM
clutch33
Jun 9, 2004 05:31 PM
dynamo
Jul 27, 2003 09:07 PM
