Name that engine/transmission sound
Old Apr 2, 2009 | 06:43 PM
AVA's Avatar
AVA
Sláinte
Default Name that engine/transmission sound
I drive a 2000 civic cx, d16y7, about 80k on the clock
in any gear, from 2200-2500 rpm's there is a constant noise coming from the engine/under the car, the front
its sort of a grinding noise, but it sounds smoother than a grind, the best way to describe it is it sounds like 2 smooth metal discs spinning opposite each other then lightly touching
it kicks in at exactly 2200 rpm's and is constant to 2500 rpm's then it just goes away. doesnt happen at any other rpm and it happens in all gears
i'm sure its not the engine because it does NOT make the noise when i rev it with the clutch in or in neutral. only when the car is in-gear and the wheels are spinning
also, in 2nd or 1st at a low speed i'm guessing the transmission is very loud. it sounds like a typical engine brake noise only its pretty loud. best way to describe it is gears turning with no lubrication
transmission fluid was replaced with REDLINE MTF about 25-30k miles ago
any help is appreciated
Old Apr 2, 2009 | 07:01 PM
sde780's Avatar
Default Re: Name that engine/transmission sound
same problem here. im thinking it has something to do with my timing being maybe slightly off - i just did a timing belt/water pump change. mine sounds like that if i give it gas, starts around 2k rpms. or could be my crank pulley, its got two chunks taken out of it. ill wait for someone else to chime in, im quite a noob with hondas
Old Apr 2, 2009 | 08:25 PM
AVA's Avatar
AVA
Sláinte
thats good, i hope its something like that, i'm driving alot more now, 2+ hours a day of mostly highway and i'm usually right around 3k, i dont want to do damage
any more info?
Old Apr 2, 2009 | 08:27 PM
ej1excoupe's Avatar
when u put the clutch in does it still make the noise?
Old Apr 5, 2009 | 10:40 AM
AVA's Avatar
AVA
Sláinte
no. with the clutch in or in neutral it does not.
Old Apr 5, 2009 | 11:11 AM
Former User's Avatar
Have you checked the exhaust heat shields?
Old Apr 5, 2009 | 11:32 AM
The_Honda_Guy's Avatar
I know that my girlfriend's 97 DX has a slight rattle through the shifter that you can hear only when the car is under load at lower RPM. It's not very loud, but it sounds exactly like what you described. My 94 EX also does this too. Both cars are manuals. I'm going to be replacing the shifter bushings in her car soon and see if it goes away.
Old Apr 5, 2009 | 12:38 PM
TravisCadello's Avatar
i had this same problem. it is the brake dust shield. its a thin metal behind the brake rotor if u bind it it rubs on the rotor this was my noise.
Old Apr 5, 2009 | 01:08 PM
AVA's Avatar
AVA
Sláinte
really? i considered that, but it doesnt make sense that its only in that specific RPM range and no other time
whats the remedy? just bend the brake shield?
Old Apr 5, 2009 | 01:41 PM
If it's RPM related I really can't imagine it being the brake dust shield. I could see if it was vehicle speed related but in this case it's not. Also, I know the brake dust shields aren't rubbing on the girlfriend's car because I just inspected the brakes.
Old Apr 5, 2009 | 02:26 PM
BryaninVegas's Avatar
Have you thought about checking your Alternator? Mine made a metal on metal noise that turned out to be the Alternator around the same mileage.
Old Apr 5, 2009 | 04:44 PM
AVA's Avatar
AVA
Sláinte
but was it constant or at a certain rpm range?
this is very difficult to diagnose. i might have to jack the car up and gas it up and find out exactly where the noise is coming from
Old Apr 5, 2009 | 05:00 PM
well mine was constant when it was the brake dust shield. u would hear it loud at 10mph like u had a bad brake pad and it was draging. but if its only in the rpms then jack it up and check it. start it and rev it in 1st gear. make sure in use jack stand and pull e brake and something in the rear tires lol.
Old Apr 7, 2009 | 01:42 PM
Mine only did it when the engine revving, especially while the transmission was engaged. If I pushed in the clutch and revved the motor a bit I would still hear it.
It sounds more like a drivetrain issue than anything.
Old Apr 7, 2009 | 01:53 PM
sde780's Avatar
It could very well be the alternator as I had to rotate mine forward, then I started hearing this. My battery light goes on when I stall or bog too
Old Apr 7, 2009 | 02:34 PM
kp's Avatar
kp
Many times it's a loose bolt somewhere on your engine or exhaust. If there's a washer on it, it'll rattle at consistent engine rpms.
Old Apr 7, 2009 | 03:52 PM
crip's Avatar
probabaly your best bet, it could be so many different things its hard to say. you said it stopped when you pushed your clutch in. does it stop when you are in motion and push the clutch in? if it only did at a certain rpm no matter moving or not i would reley be looking somewhere around the tranny clutch back of motor area. any way jack it up adn get someone to help make the car do it while you look.
Old Apr 7, 2009 | 03:59 PM
jshaw23's Avatar
It sounds like a problem that i was having in my 97 ex, at first i thought it was the throw out bearing, found that good and then was told that it was my input shaft. Never fixed cuz i did a swap but the guy that i sold it to said that fixed the problem. Could really be anything though.
xsxnosxsx
Honda Civic (2006 - 2015)
Nov 23, 2011 07:05 AM
matt_r
May 17, 2005 04:02 AM
redliner8000
Feb 19, 2004 08:49 PM
Littleredsi
14
Dec 13, 2003 10:32 AM
