rear disk swap questions
Old Apr 2, 2009 | 02:48 PM
GReddy SI's Avatar
Icon2 rear disk swap questions
ok i got gsr front and rear breaks for my eg hatch.
i got a 95 civic ex 15/16 mc , and i heard that i can use a 90-93 integra 4040 prop valve.
now my question is could i use this mc, and integra prop valve and everything work fine.
i am planning on using my stock brake booster. will this work?
bump if viewed
i am sure alot of people have a question like this
Old Apr 2, 2009 | 03:03 PM
GReddy SI's Avatar
Default Re: rear disk swap questions
bump
Old Apr 2, 2009 | 03:07 PM
superbean's Avatar
from what i've read that sounds good. The master cyl will change how the pedal feels overall, the prop valve is what corrects the amount of pressure going to the rear discs as the stock prop valve is weak for the drums in the rear. I think as long as you have the correct prop valve it will be fine.
Old Apr 2, 2009 | 03:08 PM
94EG8's Avatar
Seagull Management
If you want to retain your stock brake booster and run a 15/16MC get an MC from a '90 - '91 Civic EX sedan, it a direct bolt on. Otherwise use a non ABS Integra 15/16MC along with the Integra brake booster.
Old Apr 2, 2009 | 05:48 PM
GReddy SI's Avatar
well i just went outside to the car and the 15/16mc from the 95ex the holes dont line up,
Can i turn the brake booster upside down i can make it fit can i do that?
Old Apr 2, 2009 | 07:21 PM
GReddy SI's Avatar
all 4040 pro valve the same?
Old Apr 2, 2009 | 09:00 PM
dcsports's Avatar
bump
Old Apr 2, 2009 | 09:04 PM
CapnKrunch's Avatar
you need the brake booster to match the ej1 m/c if u want to go with that one otherwise yeah use the 91 ex m/c.
Old Apr 2, 2009 | 09:09 PM
GReddy SI's Avatar
i got a eg6 not ej1
Fo-Do Fanatic
Aug 9, 2010 02:35 AM
RenzoDaPlayboi
Suspension & Brakes
Jun 11, 2009 07:28 AM
jakfrost84
10
Mar 20, 2009 11:22 AM
cnydc2
Suspension & Brakes
Nov 25, 2006 05:57 AM
yellowjdmcrx
Jun 28, 2006 09:05 AM
