no preassure on fuel pump won't crank!!!!
Old Apr 2, 2009 | 12:24 PM
EG6KILIN's Avatar
Default no preassure on fuel pump won't crank!!!!
there is no preassure going thru my fuel pump how can i fix it?.....
Old Apr 2, 2009 | 12:26 PM
StreetRacin101's Avatar
Default Re: no preassure on fuel pump won't crank!!!!
Is it priming when you turn the key over?
Old Apr 2, 2009 | 12:34 PM
EG6KILIN's Avatar
well its not even shooting out gas thru the pump like it supposted to when you crank it
Old Apr 2, 2009 | 12:35 PM
But do you hear it trying to prime, the pump powering up. If not, check the fuses.
Old Apr 2, 2009 | 12:36 PM
Former User's Avatar
Is fuse 31, 24, or 18 blown? If not, check the main relay.
Old Apr 2, 2009 | 12:37 PM
EG6KILIN's Avatar
yeah the car primmes but i dont get fuel thru my fuel rail
Old Apr 2, 2009 | 12:39 PM
EG6KILIN's Avatar
where is the main relay located? it would help if i got it working going out to the track
Old Apr 2, 2009 | 12:40 PM
If you hear the pump priming, then the main relay is fine. Might be a bad pump or clogged fuel filter.
Old Apr 2, 2009 | 12:48 PM
EG6KILIN's Avatar
like when i turn the key over i should hear like a humm right....where is the fuel filter located
Old Apr 2, 2009 | 12:49 PM
Yes, you should hear a hum for 2 seconds and then it should shut off. The filter is near the battery on the firewall.
Old Apr 2, 2009 | 12:51 PM
EG6KILIN's Avatar
do i need to open it or something
Old Apr 2, 2009 | 12:53 PM
EG6KILIN's Avatar
ok never mind i fount the fuel filter
Old Apr 2, 2009 | 12:55 PM
Back up a step. What tests on the fuel pump have you done to make you think it's not pumping gas?
Old Apr 2, 2009 | 01:03 PM
EG6KILIN's Avatar
well the fuel filter is not it is supposted to shoot gas out of it because when i opened it gas didnt came out of there
Old Apr 2, 2009 | 01:09 PM
EG6KILIN's Avatar
nothing still but when i turn the car not to crank it i dont hear the humming noise that usually when hear when your about to turn a car...
Old Apr 2, 2009 | 01:13 PM
Are you now saying the fuel pump does not prime for 2 seconds when the key is turned ON(II)? If so, check the fuses I mentioned and the main relay.
Old Apr 2, 2009 | 01:16 PM
EG6KILIN's Avatar
well i gues i dont hear the pump passing gas im gonna try the realy see what happens
Old Apr 2, 2009 | 01:35 PM
EG6KILIN's Avatar
well i took out the relay an get an new one see what happens after if not thanks for the help guys
Old Apr 2, 2009 | 01:45 PM
Have you checked the three fuses?
Old Apr 2, 2009 | 01:47 PM
EG6KILIN's Avatar
were is the 3 fuses located at i only found 18
Old Apr 2, 2009 | 01:48 PM
31 is under the hood
24 is under the dash
Old Apr 2, 2009 | 10:13 PM
EG6KILIN's Avatar
thanks for the help you guys I think my fuel pumb just gave up I need to fix this by sat for the track my realy is good well see what happens tomorrow after I change the pump
Old Apr 3, 2009 | 02:48 AM
If the fuel pump "gave up"... you likely didnt hear it prime. When you turn the key on, but with the engine off... does the check engine light come on for two seconds and then go out, or does it stay lit?
Old Apr 3, 2009 | 05:54 AM
EG6KILIN's Avatar
i think it stays on!
Old Apr 3, 2009 | 06:03 AM
driveslow's Avatar
whats the word on this???
