no preassure on fuel pump won't crank!!!!
Re: no preassure on fuel pump won't crank!!!!
well the fuel filter is not it is supposted to shoot gas out of it because when i opened it gas didnt came out of there
nothing still but when i turn the car not to crank it i dont hear the humming noise that usually when hear when your about to turn a car...
Are you now saying the fuel pump does not prime for 2 seconds when the key is turned ON(II)? If so, check the fuses I mentioned and the main relay.
well i took out the relay an get an new one see what happens after if not thanks for the help guys
thanks for the help you guys I think my fuel pumb just gave up I need to fix this by sat for the track my realy is good well see what happens tomorrow after I change the pump
If the fuel pump "gave up"... you likely didnt hear it prime. When you turn the key on, but with the engine off... does the check engine light come on for two seconds and then go out, or does it stay lit?
