civic type r manifold on a 99-00 civic si
hi. im been doing a lot of search but i havent find anything so maybe one of you can answer my question i got civic typer intake manifold on my 99 civic si, on the si the IAT sensor is on the intake and on the type r is in the manifold as you may know, now i want to use the type r IAT sensor on the manifold because i went turbo and i dont want to drill a hole on the piping, but the si plug wont plug in on the type r sensor, becausethe sensor is circle and the si plug is square, so i found a plug that plug in in the type r sensor so my question is how the wiring goes how do i know wich wire goes wich the other wire...if any of you have done this before let me know..thanks
the colors are differents they dont match, just to tried my luck i wired them like to days ago and the car start fine but after i drive for i lil while when i stop on a light my idle goes around 400rpm kindlike it want to turn off, i guess i did the wrong wired or my IAT is bad i went to auto zone yesterday and the code p0113 came up is IAT high input so what could it be bad IAT sensor or that i did the wrong wiring and is not reading. any ideas
go-fast_integra
20
Sep 29, 2010 06:42 PM
6doorsentra
11
Sep 11, 2006 04:24 AM
RuffRhyno
Aug 12, 2004 05:50 PM
