b17 build questions pics!!
well im building my b17 got it from PHOKyu with jdm b16 pistons and im running a jdm b16 head. My question is can I use a p72 gsr ecu and gsr distributor?
heres a picture of it just for the **** of it.
From: New York in the summer, South Carolina in the winter
Whats up with the LSVTEC oil plug on the back? You untapped the head right? (pulled the plug out, and had it milled)
i dont think you want a p72 ecu since you aren't running a p72 head or intake manifold, get a p28 or p30 or p61 if you are running a b16 head.
Yes you can use the dizzy, No to the ecu b/c you can not run a gsr 2 stage intake with a b16 head. Stock ecu's you can run are a p30, or a p61. You can run a p28 if it is chipped for b series use. I am pretty sure the pulse rate between D and B series injectors are different.
gser.typer
Aug 22, 2009 04:36 PM
