how do I check my CEL w/o the jumper
Old Apr 1, 2009 | 06:53 PM
turbo sol's Avatar
Default how do I check my CEL w/o the jumper
i have a obd2-obd1 harness in my 96 hatch.
i have a p28 in the car. everything seems to operate normaly.
upon start up the CEL comes on for 2 seconds then goes away like normal. But I just recently started throwing a CEL.
I went to jump the service connector by the ECU (the 2 pin plug) and nothing happens. My SRS light comes on, but not the CEL.
How can I check the CEL without the connecter? can't I connect 2 wires at the ECU and accomplish the same thing?
any help from the wiring guru's around here would be great.
Old Apr 1, 2009 | 07:10 PM
twiztid_989's Avatar
Default Re: how do I check my CEL w/o the jumper
when u jumped tha 2 pin plug and no cel light comes on then no codes
Old Apr 1, 2009 | 07:11 PM
Ya Digg's Avatar
was the car off then put in the "on" position? or did u start it? Reset te ECU and see if it comes back.
Old Apr 2, 2009 | 07:07 AM
turbo sol's Avatar
twiztid_89:
when jumped, the CEL does not come on and it does not flash codes. BUT the SRS light does come on. If I reset the SRS light and dont jump the plug, the SRS light only comes on as I start the car then goes off (normal operating procedure)
Ya Digg:
car was in on. not started.
Does this help at all?
Old Apr 2, 2009 | 05:31 PM
turbo sol's Avatar
(obd1) = D4-SCS service check connector Brown/Wht, ~5V (M/T); ~11V (A/T)
according to the helms the service connector ground out the wire. so I grounded it, and the CEL comes on, but it doesnt' flash - it just stays solid?
should it at least flash the all clear code?
4DALOOKS92
Apr 16, 2016 07:46 AM
streethondar
May 10, 2015 07:12 PM
SrT4u2nV
28
Feb 8, 2007 09:26 AM
stealth89hatch
Aug 15, 2005 04:48 PM
