GSR headbolt threads stripped in block
Old Apr 1, 2009 | 06:13 PM
EgHatch311's Avatar
New User
Post GSR headbolt threads stripped in block
NEED HELP i have a eg civic hatchback with gsr block b16 head. blew a head gasket then after getting the head back from the machine shop found out the headbolt threads were stripped on the block. ive considered a heli coil or timesert but ive heard of people retapping the block to hold a fatter head bolt. i know the gsr bolts are 11mm but idk the thread pitch. i want to retap the block for a 12mm head stud. can someone give me the dimensions on a stock gsr headbolt so i can order the right head studs and is it a good idea to do this
Old Apr 1, 2009 | 08:29 PM
integraGSR1's Avatar
Default Re: GSR headbolt threads stripped in block
if it all comes down to it, you can put in a timesert. don't know how good they are on headbolts. i have done timeserts on spark plugs before, but this is the head we are talking about. there is a place here in SAC that does timeserts and will warranty it i think.
anyhow, the head bolt it 11 x 1.5mm, straight out the repair manual. 2 step torque, once to 22, then another time to 60ft lbs.
Old Apr 2, 2009 | 10:11 AM
boost'd_crx's Avatar
timsert is probably ur best choice at this point. i used them and it works great.
Old Apr 2, 2009 | 11:12 AM
redflaredcrx90's Avatar
take it to a machine shope and have them do it right and have the rechase the thread that ways its being dont right and for that reasson if you blow the head gasket again you wont mess up ya motor
Old Apr 3, 2009 | 07:22 PM
EgHatch311's Avatar
New User
yea im going to try the time sert thanks for the help.
Old Apr 3, 2009 | 07:25 PM
EgHatch311's Avatar
New User
do u know were i can get the timeserts.
Old Apr 3, 2009 | 08:34 PM
i think you can get them at auto parts store. they sell them in a kit. it comes with the drill bit, tap, driver, and a couple of timeserts.
willard steen
Apr 5, 2016 12:22 AM
nelson9994
Nov 30, 2011 03:29 PM
FadedDC2
Jun 13, 2007 02:16 PM
gd99em1
May 14, 2007 07:08 AM
