K20 swap into ek
So its coming out of a friends type s he rolled it and im buying the car from insurance. what all will a need to buy to swap it. the engine,harness,ecu,tranny...all that is good.
So will like the axles fit?
Can i do a 5lug conversion with those hubs?
make sure to search the info up...and GL.
you need new mounts, an engine harness-harness, fuel setup, radiator, radiator lines, header, shift box mount kit, axles depending on what hubs/mounts you use, subframe/steering rack/lca's depending on what mount kit u go with, check out k20a.org for more info
sleepyaccord96
27
Aug 22, 2013 09:34 AM
minime97ek
Mar 27, 2013 07:07 AM
portfl0w
Dec 12, 2006 07:06 AM
EK SQUAD 425
Mar 24, 2006 06:45 PM
