f23a1
Old Apr 1, 2009 | 02:27 PM
cjam37's Avatar
New User
Default f23a1
I have a 98 Honda Accord Ex automatic with a f23a1 motor i want to make some serious power out of this engine. What mods can i make on a budget.
Old Apr 2, 2009 | 06:43 AM
H23 Power's Avatar
Default Re: f23a1
serious power on a budget = nitrous.
Old Apr 2, 2009 | 06:59 AM
GhostAccord's Avatar
Default Re: f23a1
& a blown A/T transmission.
My suggestion would be to ditch the A/T before you look into any kind of serious power.
Old Apr 2, 2009 | 11:56 AM
AFAccord's Avatar
Default Re: f23a1
Fast, Cheap, Reliable...
Pick two. Nitrous is probably your only option.
Old Apr 4, 2009 | 06:16 AM
cjam37's Avatar
New User
Default Re: f23a1
What about fast and reliable without nitrous
Old Apr 4, 2009 | 06:34 AM
AFAccord's Avatar
Default Re: f23a1
Fast and reliable wont be cheap.
Old Apr 4, 2009 | 10:12 AM
FunnyVictor86's Avatar
Default Re: f23a1
massive power + reliability = $$$$$$$$$$ ... as stated above by ghost a 5 speed swap is a must ... those A/T's can't even handle much of a beating with a stock motor
Old Apr 4, 2009 | 10:18 AM
ekmushi_mushi's Avatar
Default Re: f23a1
1 fast + reliable = time and money.. AKA manual swap ..then turbo..greddy kit should do it
2.nitrous ..but even at still cant handle them nitrous...only like dry shot
3.f23a1 series motor is like d series in civic ...cant make alot of hp until u do something different..
4.swap it..idk but...accord from 98-02 have tranny recall. so swap out the tranny before it go on u
Old Apr 4, 2009 | 01:01 PM
Default Re: f23a1
wet shot would be more "reliable" or safer than a dry shot ... either way i think nitrous is a waste ... it's more for "emergency" purposes or straight drag
Old Apr 4, 2009 | 06:32 PM
kingofbattle909's Avatar
Default Re: f23a1
h22 head, h22 pistons and bore block to 87mm, ecu, prelude 5 speed swap.
check out the "hybrid" section here, look for g23.
and check out this site: http://zealautowerks.com/hfseries.html...
good luck!
Old Apr 4, 2009 | 09:18 PM
Default Re: f23a1
^ you might as well swap a h22 if your going to spend that kind of money ... swap is cheaper
NeverOne
May 3, 2007 02:01 AM
coreytheblade
Aug 21, 2006 06:07 AM
civicblackcrx
Jun 5, 2005 05:23 PM
1750cc
Apr 5, 2005 06:50 PM
el_Presidente
Apr 26, 2002 01:50 PM
