My friend is having some wierd problems...need help.
Old Apr 1, 2009 | 01:19 PM
Teamdiesel's Avatar
Default My friend is having some wierd problems...need help.
My buddy from down the road is having some issues with his Type R that just stump me. He has a totally stock ITR with 55,000 kms on the car. He recently purchased an authentic Mugen N1 ECU and used it on his car a few times to drag race. He came to my house yesterday claiming that the car was sluggish after using the ECU a few days earlier. He was now using the stock ECU again and upon driving the car, it had a draw back in power at around 3000 rpms. It happens during casual driving and sometimes during acceleration. When I started the car i noticed that it idled very low, but would rev out clean. i did a compression test and it held 240psi on all cylinders, so I decided to check ignition timing at the distributor. When i pushed the dizzy full advance, the timing light registered a max of 13 degrees advance??? I told him to have his dizzy checked, to which he replaced the igniter with a genuine unit...same problem. He had the coil changed....same problem. What could be his issue??? Oh, i forgot that he admitted to me that he was tempted to see the Mugens redline, and took it to 9500rpms on stock everything .
Old Apr 1, 2009 | 01:49 PM
iwanttokillgod's Avatar
Default Re: My friend is having some wierd problems...need help.
check the timing belt it may have skipped a tooth
Old Apr 2, 2009 | 03:37 PM
Teamdiesel's Avatar
here is a pic of the cam gears at TDC on cylinder #1.
Old Apr 2, 2009 | 03:59 PM
Teamdiesel's Avatar
here is a quick vid.
[URL=http://s39.photobucket.com/albums/e184/Teamdiesel/?action=view&current=P4020478.flv]
Old Apr 2, 2009 | 05:17 PM
Teamdiesel's Avatar
bump for any input.
Old Apr 2, 2009 | 05:32 PM
Garcia-Racing's Avatar
Is the tensioner failing? Looks pretty loose.
Old Apr 2, 2009 | 06:05 PM
mar778c's Avatar
Community Builder
Community Influencer
It's hard to tell, but I would start from scratch and reset the timing. Also, the belt is loose to me.
DCRX89
Sep 18, 2014 01:35 PM
DeleriouS25
Oct 11, 2007 10:13 PM
rotary1
Sep 1, 2007 03:35 PM
cool_as_crap
May 16, 2006 09:28 AM
Kevin Type Si
May 24, 2004 11:35 AM
